Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through November 22, 2004 >
NetStreams’® SwitchLinX™ Integrates Virtually Unlimited Sources Into the Digi...
NetStreams’® SwitchLinX™ Integrates Virtually Unlimited Sources Into the DigiLinX™
| Posted by Marketing Ma... on Friday, October 08, 2004 - 11:27 am: |
“Not just any Ethernet switch can meet the high demands of audio and video distribution of a TCP/IP network,” said Herman Cardenas, founder and chief executive officer of NetStreams. “SwitchLinX SW224 and SW208 are IGMP-enabled to ensure the reliable transmission of all high-fidelity audio streams throughout the home.”
SwitchLinX can auto detect a 10/100Mbps-speed, full/half duplex mode, MDI/MDI-X connection and provides an option for one 100Base-FX expansion module port for the addition of two GB switches. LEDs for power status and link/activity allow a user to easily check the status of the network connections.
SwitchLinX supports Ethernet connections of up to 328 feet and can be used as a network extender for longer distances. Two models of SwitchLinX are available to suit the needs of any size custom installation. The SW208 supports 8 nodes and the SW224 supports 24 nodes. Multiple SwitchLinX devices can be cascaded for system scalability.
NetStreams DigiLinX family of IP-based products offers very high quality and high performance audio distribution and control with capabilities never seen before, and a rich user experience only available in high cost systems today. This innovative product line, using NetStreams’ patent pending technology, is the first IP-based multi-room audio system in the custom market; ‘IP-based’ meaning a system that is not only controlled over IP, but also distributes its audio and video over packet-switched streams. DigiLinX delivers on the promise of convergence, effectively marrying networking technologies with hi-fidelity audio and later video, marking the introduction of ‘Networked Digital Entertainment’.
SwitchLinX Features:
• IGMP-enabled
• Optimized for audio/video distribution over TCP/IP
• Complied with IEEE 802.3 10Base-T, 802.3u 100Base-TC, and 100Base-FX standards
• Each TP port supports both 10/100 Mbps auto-negotiation and auto-MDI/MDI-X connections
• Supports duplex operation for each port
• Store-and-forward architecture
• Broadcast storm protection
• Supports full-duplex flow control (IEEE 802.3x)
• Supports QoS function, the tag in an Ethernet packet contains priority information of packets. Per port provides 4 transmit queues
• 19” rack-mountable (removable rack ears)
SwitchLinX Specifications:
• Switch Fabric: 80 Gb
• Fiber Port: Multimode/Single Mode Duplex ST or SC connector
• Fiber Media: Multimode:1300nm 62.5/125µm fiber cable (2km max.)
• Single Mode: 1300nm 9/125µm fiber cable (20km max.)
• Standards: IEEE 802.3 10Base-T Ethernet, IEEE 802.3u 100Base-TX, 100Base-
FX Fast Ethernet
• Filtering Address: Unicast/Multicast/Broadcast
• Filtering Rate: 14,880 pps for Ethernet, 148,800 pps for Fast Ethernet
• Forwarding Rate: 14,880 pps for Ethernet, 148,800 pps for Fast Ethernet
• Connector: Shielded RJ-45 jack
• LED Indicators: Link/Activity, Full Duplex/Collision status for each port
• Environment: Operating Temperature: 0º C to 50º, Storage
• Temperature: -40º to 70º C
• Relative Humidity: 5% to 95% non-condensing
• Power: 100-240VAC,50-60 Hz,16W (max)
• Dimensions: 17.3”W x 6.8”D x 1.7”H (440mm x 172mm x 43mm)
• NetPower™: 0
About NetStreams
Headquartered in Austin, Texas, NetStreams provides sophisticated networked audio leading the marketplace in technological innovation. NetStreams is committed to utilizing state-of-the-art human engineering to create home entertainment products that are truly user-friendly and future-compatible. NetStreams is creating the future of home entertainment today.
For additional information on NetStreams and its innovative products, please visit www.netstreams.com.
NetStreams is a registered trademark of NetStreams. SwitchLinX is a trademark of NetStreams.
