Home > Message Board > Press Releases > Archive through 2008 > Archive through November 22, 2004 > Panamax Introduces 12 New Ways to Greater Power Conditioning & Protection
PETALUMA, CA – September 2, 2004 – Panamax, America’s leading manufacturer of power conditioning and protection products, introduced its newest floor models under three new lines: POWERMAX, PREMIUM and PRO Series. Each series delivers clean and safe power to enhance the performance of audio & video systems and home & office equipment. Panamax’s new powerful conditioners protect a variety of A/V signal types in addition to AC power, and deliver many new innovative features such as increased noise filtration, over and under voltage power monitoring and control, modern cord management design separating high voltage and low voltage circuits to eliminate noise, optional add-on signal protection modules for systems that require expanded protection, and elegant brushed silver or black metal enclosure accents.
“We developed the new power conditioners to give installers solutions for guaranteeing maximum value from each of their electronic system installations,” said Don King, director of product marketing at Panamax. “The POWERMAX, PREMIUM and PRO Series provide clean power for optimum performance of noise-sensitive components in home theaters, computer networks, and more. Most models also feature integrated signal line protection for simple, all-in-one coverage of a variety of cutting-edge systems.”
Panamax designed the 12 new floor models to protect AC power as well as signal and data lines used in popular home and office applications. Each conditioner features four or eight surge-protected outlets, which use Panamax’s Protect or Disconnect™ circuitry to block catastrophic surges from damaging connected equipment. Since surges can reach systems through any cable or wire type, the new conditioners include surge protection for CATV & cable modems, satellite TV lines, and Telco & LAN connections. Top panel LEDs alert users to changes in the units’ power protection, grounding status, voltage level, and DC trigger signal engagement. Wall-mounting brackets are included for fast and easy installations if wall mounting is desired.
Each model in the new series accepts add-on signal modules available for protecting analog and digital telephone lines, cable and satellite TV, Ethernet lines, and control/external speaker lines. Multiple modules can be combined to fully cover complex systems. The PRO Series adds a bank of isolated high current outlets, a 12 volt trigger for power management, flashing unsafe voltage LED.
For Home Theater/Home Entertainment Systems
M8HC-PRO $149.95
PRO SERIES: 8 AC outlets (2 isolated, 4-outlet banks);Patented Power Management Circuit, over/under voltage shut-off; 12V trigger input; Satellite TV (“F” connectors); CATV/Cable modem protection; LAN protection 10/100bT; Telco protection RJ-45 shared with LAN
M8C-PRO $129.95
PRO SERIES: 8 AC outlets (2 isolated, 4-outlet banks);Patented Power Management Circuit, over/under voltage shut-off;12V trigger input; Satellite TV (“F” connectors);CATV/Cable modem protection; LAN protection 10/100bT; Telco protection RJ-11
M8DBS-EX $99.95
PREMIUM SERIES: 8 AC outlets; Patented Power Management Circuit, over- & under voltage shut-off; Satellite TV (“F” connectors)CATV/Cable modem protection; LAN protection 10/100bT;
Telco protection RJ-11/45
M8C-EX $79.95
PREMIUM SERIES: 8 AC outlets; patented Power Management Circuit, over- & under voltage shut-off; LAN protection 10/100bT;Telco protection RJ-11/45; CATV/Cable modem
PM8DBS-EX $79.95
POWERMAX SERIES: 8 AC outlets; Telco protection RJ-11; Satellite TV (“F” connectors);CATV/Cable modem protection bi-directional
PM8C-EX $59.95
POWERMAX SERIES: 8 AC outlets;Telco protection RJ-11; CATV/Cable modem protection bi-directional
For Home & Office Equipment
M8T-EX $69.95
PREMIUM SERIES: 8 AC outlets; Patented Power Management Circuit,over- & under voltage shut-off; LAN protection 10/100bT;Telco protection RJ-11/45
M4T-EX $59.95
PREMIUM SERIES: 4 AC outlets; Patented Power Management Circuit,over- & under voltage shut-off LAN protection 10/100bT;Telco protection RJ-11/45
M8-EX $49.95
PM8T-EX $39.95
POWERMAX SERIES: 8 AC outlets; LAN protection 10/100bT;Telco protection RJ-11/45
M4-EX $39.95
4 AC outlets; on/off switch–circuit breaker combo; Patented Power Management Circuit, over- & under voltage shut-off
PM8-EX $29.95
POWERMAX SERIES: 8 AC outlets; on/off switch–circuit breaker combo
Panamax’s new POWERMAX, PREMIUM, and PRO Series are now shipping nationwide.
Panamax - The Industry's Leader in Innovation and Technology
Panamax has been the premier power-conditioning manufacturer in the consumer electronics industry for nearly 30 years. Panamax has a staff of 5 full-time research & development specialists, and has introduced many technological innovations to the power-conditioning product arena. Panamax also has a high-power test laboratory that is certified by CSA to perform agency testing, and has drawn on an unparalleled understanding of noise filtration and surge protection to create the finest power-conditioning products available in the market today.
About Panamax
For nearly 30 years, Panamax has specialized in producing the most innovative power-conditioning products available to protect home and small business electronics equipment from damage caused by power surges and lightning. The company’s extensive line of award-winning power conditioners is designed to safeguard a wide array of electrical equipment including computers, telephone systems, copiers, domestic appliances, home theater and direct broadcast satellite systems. Panamax is ISO 9001 certified and it markets its line of power conditioners throughout the U.S., Canada, Latin America and the Pacific Rim. The company has earned numerous industry awards, and is backed by outstanding customer service and the best warranties the industry has to offer.
