Home > Message Board > Press Releases > Archive through 2008 > Archive through January 03, 2005 > New CAT5-5000 HD from Gefen Extends Two Digital High Definition Displays Plus...
New CAT5-5000 HD from Gefen Extends Two Digital High Definition Displays Plus Keyboard/Mouse with CAT-5 Cables
WOODLAND HILLS, CA – December 4, 2004 – Connectivity solutions provider Gefen today announced the release of its CAT5-5000 HD, a KVM extender capable of spanning distances up to 150 feet. The CAT5-5000 HD utilizes a new chip technology capable of sending DVI digital video plus USB and optional digital audio signals over CAT-5 cables, offering an alternative to some of the costs associated with DVI copper and fiber optics cabling.
The extender works through a sender unit connected to the computer and a receiver unit connected to the extended peripherals; CAT-5 cables link the sender to the receiver.
The slim, rackmountable units come equipped with two DVI connectors that support the extension of two digital displays. USB is provided for a keyboard/mouse connection but could be used for any USB device. Optional digital audio support is offered for SPDIF or optical signal extension over CAT-5 cable. High resolutions up to 1920x1200 are supported. A five-volt power supply feeds the system.
The CAT5-5000 HD is often used to isolate computer fan noise in sound sensitive post-production facilities, and enables computer equipment to be centralized in safe, temperature-controlled environments.
Additional information on Gefen’s entire line of KVM extenders and the CAT5-5000 HD ($1299) may be found at www.gefen.com, where products may be purchased directly or through one of Gefen's resellers listed online.
About Gefen Inc:
Gefen provides computer and electronics connectivity solutions through its ex-tend-it Professional Series, offering multi-platform extension, switching, distribution and conversion technologies. Gefen’s new HDTV solutions split, switch, convert and extend high definition digital video at its highest resolutions. SDI, HD-SDI, HDMI, fiber optics, DVI, Dual-Link DVI, CAT5 and similar solutions are also available through Gefen as well as a variety of cabling.
