Home > Message Board > Press Releases > Archive through 2008 > Archive through January 03, 2005 > CES'05: Thorens debuts high-end turntable
Press Release - NO EMBARGO
For CES 2005 January 5 2005
imported by Trian Electronics
Alexis Park room AP 1103
www.triancorp.com
www.thorens.ch
US importers Trian Electronics,
THORENS TD 2030A analog turntable $3299.00
A stunning crystal blue design, with performance to match the looks
Behind the new TD 2030 lies over one hundred years of turntable manufacturing knowledge. To this, the 2030 adds the newest materials technology and the latest tools in research and development.
The chassis is 1.3 inches deep, made from a bonded sandwich of polished clear Acryl, with superb anti resonant characteristics. The 1.4 inch thick platter is a perfectly machined polished alloy disk weighing over 13 lbs, balanced and fitted with a vibration damping backside coating. The external motor is a state of-the-art unit enclosed in it’s own housing and isolated from the chassis for reduced noise. The newly developed silent-run bearing is an integral part of the design, a unique ceramic sleeve substantially reducing friction and noise compared with a typical bronze sleeve. This advanced bearing runs dry, without any maintenance during it’s whole lifetime. All this is decoupled with proprietary adjustable isolation points. Playback is through the Thorens TP300 pickup arm which offers exceptional performance at a reasonable cost. With outstanding design & engineering, the TD 2030 is a long-term investment in musical pleasure.
Drive System:
- Thorens Belt drive with a fully electronically regulated AC-Synchronous motor
Speed:
- 33, 45 rpm  with electronic speed select
Platter:
- 1.4 inches deep / 11.8 inchs dia / 13.2 lbs. non magnetic.
Tonearm:
- Thorens TP 300 with VTA adjuster and magnetic antiskating
Power Supply:
- Electronically regulated Power Supply for AC Motor.
Dimensions:
- (wxdxh) inches: 16.5x13x6.5 Weight: 34 lbs.
The measured values for wow and flutter, rumble and signal-to-noise ratio are so low and insignificant that Thorens have decided not to publish them.  Technical alterations may be made without prior notice.
THORENS, headquartered in Basel, Switzerland manufactures high quality turntables for the consumer market
TRIAN ELECTRONICS, INC. is an importer and distributor of high-end professional audio and consumer audio products, including ELAC loudspeakers, Thorens turntables and Vincent audio components from Germany and Audia Flight from Italy, serving the broadcast, studio, contracting and hi-fi markets, with corporate headquarters located at 5812 Highway K, Waunakee, WI 53597.
elac, thorens,
audia flight and vincent
hi-fi and home cinema electronics and
loudspeakers plus audiophile turntables
distributed by trian in the usa
608-850-3600
http://www.triancorp.com
