Home > Message Board > Press Releases > Archive through 2008 > Archive through January 03, 2005 > CES'05: Elac launch in-wall speakers inc high-end model
Press Release - FOR IMMEDIATE RELEASE
CES 2005 January 5 2005
LVCC South Hall 1, booth # 21661
and the Alexis Park room AP 1103
ELAC of Germany introduces In-Wall speakers at CES 2005
The two new models embody the finest in German engineering and
the IW1230 featuring the Jet III ribbon tweeter is one of the best
sounding in-wall designs available. Think Audi, think BMW, think Elac,
the engineering ethos is the same.
- Elac IW1230 Ribbon Tweeter In-Wall loudspeaker - price TBA
The In-Wall for audiophiles! Matching the Elac 200 series, the
IW1230 In-Wall speaker features the same Aluminum Sandwich
(AS) woofer and JET III ribbon tweeter all housed in a sealed
in-wall enclosure. The IW1230 offers exceptional detail and imaging,
excellent integration with traditional loudspeakers and with any decor.
- ELAC JET III ribbon tweeter provides
smooth detailed frequencies to beyond 50kHz
- Shielded drivers for minimum magnetic
interference with video equipment
- Arctic white grill and frame, paintable to match any decor
- Self-resetting overload fusing prevents
damage from accidental over-powering
- Sealed enclosure optimizes bass response
and minimizes dust build up near ports
- Adjustable tweeter response switch
- Includes installation template and grill removal tool
Dimensions HxWxD
308 x 220 x 105 / 115 mm
Nominal / Peak Power Handling
55 W / 80 W
Recom. Amplifier Power at Nominal Impedance
30 - 150 W / channel
Frequency response
60 - 40000 Hz
Sensitivity
86 dB/2,8V/m
Nominal impedance
8 ohms
Tweeter 1 x JET III ribbon
Woofer 1 x 140 mm AS cone
- Elac IW1030 In-Wall loudspeaker - $150.00 each
The Elac IW1030 in-wall speaker offers a high quality, high value
loudspeaker option. Using the same neodymium drive tweeter and
165 mm cellulose diaphragm woofer featured in the Elac 50 series,
the IW1030 provides consistent performance and balance when
mixed with traditional speakers.
Dimensions HxWxD
308 x 220 x 105/115 mm
50 W / 70 W
Recom. amplifier power at Nominal Impedance
30 - 150 W/channel
Frequency range
75 - 23000 Hz
Sensitivity
89 dB/2,8V/m
Nominal impedance
8 ohms
Tweeter 1 x 25 mm dome
Woofer 1 x 165 mm cone
elac, thorens,
audia flight and vincent
hi-fi and home cinema electronics and
loudspeakers plus audiophile turntables
distributed by trian in the usa
608-850-3600
http://www.triancorp.com
