Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through January 03, 2005 >
HDX Audio launches new speaker at CES Las Vegas
| Posted by HDX AUDIO on Monday, January 03, 2005 - 11:27 am: |
The model "THE KING" redefines the term "THE BEST OF THE BEST". This is a "TIME COHERENT" and "DISPERSION COHERENT" speaker capable of frequency response of 18 Hertz up to 23,000 Hertz. The cabinet uses the exclusive "Hansen Composite Matrix" material with the HDX "CLASS A" finish.
The Tweeter is engineered, designed and manufactured by HDX Audio. A 25mm Pure Beryllium dome is mounted on a 1/4 inch aluminum plate, driven by a "TH" type motor assembly.
The Mid Band and the Woofers are engineered, designed and manfactured by HDX Audio using "PK" type multi layer cone and the "TH" type motor assembly mounted on the "HDX Architecture" frames.
"The KING" uses a HDX Audio engineered, designed and manufactured 3 way "Phase Coherent" hand assemblied Crossover.
The terminal connections are "WBT SIGNATURE PLATINUM" connectors. The "WBT" have High Current pole terminals with decreased transition resistance.
All this results in a marriage of advanced scientific research, dedication to a philosophy of uncompromising quality, purity of sound, and graceful elgant cabinets.
While words can convey something of the craft and science that make HDX Audio High Performance speakers "The best of the best", only when listening can you fully appreciate how truly great they really are.
Price for the HDX Audio model "THE KING" is $50,000 USD per Pair.
