Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through January 26, 2005 >
Gefen Releases High Definition Source Switcher and Extension Solutions
| Posted by Linda Morgan on Thursday, January 13, 2005 - 03:36 pm: |
The DVI-DL Switcher (MSRP $699) allows you to connect two sources to a display equipped with just one input. You select which source to view manually or with a remote control. The switch between sources occurs instantly, offering immediate access to the source.
The DVI-2000 HD (MSRP $1399) uses a sender and receiver system to send dual link DVI video up to 1640 feet (500 meters) over fiber optic cables. The sender unit connects to the source and the receiver unit to the extended display. Sender and receiver are linked by multimode fiber optic cables designed to prevent signal degradation at long distances.
Both the 2x1 DVI-DL Switcher and the DVI-2000 HD are engineered to deliver high definition video that is HDCP (high bandwidth digital content protection) compliant. Both will be available online at www.gefen.com or through a Gefen reseller.
About Gefen:
Gefen provides consumer electronics and audio/video connectivity solutions with multi-platform extension, switching, distribution and conversion capabilities. Gefen is consistently the first to deliver advanced technologies for home theater, computers and other AV environments. Products support high definition digital video, analog video and digital and analog
audio using various interfaces such as HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, USB, Firewire and RS-232. A wide selection of cabling is also available through Gefen. Detailed information may be found online at www.gefen.com.
