Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through April 06, 2004 >
Meridian’s MLP lies at the heart of every DVD-A player, almost every disc
| Posted by Sue Morgan on Tuesday, February 10, 2004 - 04:05 pm: |
Nicoll Public Relations
781-762-9300
Sue@Nicollpr.com
Meridian – Everywhere!
February 2004—Huntingdon, UK-based Meridian Audio Limited is known internationally for its acclaimed hi-fi and home theater products, where it is the recognized leader in all-digital audio/video systems with such products as the multiple award-winning Reference Series 800 player and 861 surround processor, the acclaimed DSP7000, DSP8000 and other DSP-based loudspeaker systems, and the extensive, elegant new G Series.
What is perhaps less well known is the widespread nature of Meridian’s innovative technology. For many years, Meridian has written its own software for surround decoding, optical disc navigation and system control, rather than buying it in from elsewhere, allowing the company to react quickly to new developments and solve problems caused, for example, by an errant disc. However, the company was also responsible for one of the core technologies in the latest and most advanced audio distribution format, DVD-Audio, thanks to MLP – Meridian Lossless Packing – the lossless compression technology employed in almost every DVD-Audio disc.
DVD-Audio is a member of the DVD (Digital Versatile Disc) family, the most successful consumer for-mat ever. DVD-Audio uses the same DVD disc technology, with the ability to store 4.7 GB per layer, per side, and each side can have up to two layers. But instead of storing video on the disc, the majority of the space is used to store super-quality multichannel advanced resolution audio – six channels of up to 96 kHz, 24-bit sampling or stereo at up to 192 kHz. That means a frequency response of up to 100 kHz and a dynamic range in excess of 140 dB over that entire range – a level of quality and detail un-matched by any other audio format.
But there was a challenge in getting this super-quality audio on to the disc. The data rate of DVD-Audio is 9.6 Megabits per second. This would limit the playing time of 5-channel audio at 96 kHz sam-pling to 65 minutes and 20-bit resolution, while 6 channels of 24/96 would exceed the allowable data rate. The obvious answer was compression, which is how a movie can fit on to a disc, but lossy com-pression had been ruled out by the record industry in specifying DVD-Audio. So lossless compression – where the data recovered from the disc is identical to that originally encoded on it – was the way to go. An international competition was held to choose the technology, and Meridian’s MLP was the clear winner.
MLP allows 6 channels of 24/96 super-quality PCM audio to be carried on the disc, with a playing time of up to 86 minutes – or 74 minutes while leaving room for popular extras such as music videos, lyric sheets, slide shows, DVD-Video player compatibility and all the other features that make DVD-Audio the outstanding advanced-resolution music carrier and market leader it is today.
In a DVD-Audio player, MLP decoding is intricately woven into the high resolution PCM audio tech-nology used for DVD, making the decode process relatively inexpensive – the cleverness is in the en-coding system used during authoring, requiring much less sophisticated processing in the player itself. In addition, MLP is extensible, with metadata and flags in the data stream that can signal the player and provide information about the type of material being played. For example, in addition to support-ing conventional 5.1 surround, MLP can allow DVD-Audio – or future media using MLP technology – to support different channel configurations and surround-sound techniques, including those that have not yet been defined.
Today, MLP is included in the over 160 DVD-Audio player models, from 35 manufacturers – a total of more than 10 million players – plus the two million or so computer-based DVD-A replay systems now in the marketplace, and licensing of the technology is handled by Dolby Laboratories. Every time you see the MLP logo on any DVD-Audio player, or listen to virtually any DVD-Audio disc, you’re experiencing Meridian technology in action. Meridian – at the heart of DVD-Audio. Visit www.meridian-audio.com for more information.
