Home > Message Board > Press Releases > Archive through 2008 > Archive through March 03, 2005 > NetStreams’® New KeyLinX™ KL100 and KL200 Intuitive Keypads Work Seamlessly w...
NetStreams’® New KeyLinX™ KL100 and KL200 Intuitive Keypads Work Seamlessly with the DigiLinX™ IP-Based Multi-Room Audio System
Austin, TX – February 25, 2005 – NetStreams, the leader in IP-based Networked Audio/Video distribution, is pleased to introduce the KeyLinX KL100 and KL200 single-gang in-wall keypads, designed to work seamlessly with NetStreams DigiLinX IP-based Multi-Room Audio System. Ideal for basic audio control in smaller rooms or sub-zones, both of these keypads can be connected directly to the EIM (Expansion Interface Module) connection on the SpeakerLinX Room Controller / IP-based Amplifier. Both KeyLinX keypads will begin shipping in March of 2005.
“We developed the KeyLinX KL100 and KL200 keypads to expand the pricing options of a typical DigiLinX installation. Both pads are excellent entry-level solutions for rooms where an LCD touchpanel controller is not necessary, such as a smaller room or a sub-zone,” said Herman Cardenas, founder and chief executive officer of NetStreams.
KeyLinX keypads feature 10 laser-etched hard key buttons for easy and intuitive source selection and operation. Attractive, green LEDs clearly display the volume level of the source equipment, and the PC-based DigiLinX Dealer SetUp Program makes programming the hard keys a simple operation.
Both the KL100 and the KL200 feature two EIM connectors on the rear panel – one to connect to the SpeakerLinX Room Controller/IP-based Amplifier and one to connect to an optional Audio Port, thus adding a local source to that room. Both keypads also feature a built-in IR window for the pass-through of IR to a local source, which may be connected to the optional Audio Port.
In addition, the KeyLinX KL200 features a built-in microphone for future Voice-over-IP applications, as well as another LED for “monitor,” “do-not-disturb,” and “message” modes.
NetStreams’ DigiLinX family of IP-based products offers very high-quality and high-performance multi-room audio, control capabilities never seen before, and a robust user experience only available in high-cost systems. This innovative product line, using NetStreams’ StreamNet™ patent pending technology, is the first IP-based multi-room audio system in the custom market; ‘IP-based’ meaning a system that is not only controlled over IP, but also distributes its audio and video over packet-switched streams. DigiLinX delivers on the promise of convergence, effectively marrying networking technologies with hi-fidelity audio—and later video—marking the introduction of ‘Networked Digital Entertainment’.
KeyLinX KL100 and KL200 Features:
Standard single-gang box compatibility
Blue LEDs for volume status
Mounting brackets
Available in white, almond, ivory and black
KeyLinX Specifications:
2 RJ-45 (*EIM Connections)
Built-in Microphone (KL200 only)
In-Wall Dimensions (WxHxD): 1.5” x 2 11/16” x 1.1” (38mm x 68mm x 28mm)
External Dimensions (WxHxD): 2 ≤” x 4 5/8” x 1” (70mm x 117mm x 28mm)
NetPower™: 0
About NetStreams
Headquartered in Austin, Texas, NetStreams provides sophisticated networked audio leading the marketplace in technological innovation. NetStreams is committed to utilizing state-of-the-art human engineering to create home entertainment products that are truly user-friendly and future-compatible. NetStreams is creating the future of home entertainment today.
For additional information on NetStreams and its innovative products, please visit our website at www.netstreams.com <http://www.netstreams.com/> .
NetStreams is a registered trademark of NetStreams LLC. DigiLinX, KeyLinX, SpeakerLinX, StreamNet and NetPower are trademarks of NetStreams LLC.
