Home > Message Board > Press Releases > Archive through 2008 > Archive through April 12, 2005 > Adept Response Master Power Conditioner
Audience, LLC introduces the Adept Response High Resolution Master Power Conditioner. In addition to power protection, RF filtration, and partial power factor correction, the AdeptResponse offers 12 outlets, each of which is individually filtered and isolated. Thus an entire audio and/or video system can plug into the adeptResponse; digital sources can be plugged next to phono pre-amplifiers without interference. Power amplifiers of all sizes operate better, without the usual limiting of dynamics. Only the finest components are used starting with the Audience powerChord which is connected via a 20 amp Neutrik Powercon connector. The on/off switch is a heavy duty magnetic circuit breaker. The adeptResponse is offered in silver and black.
The adeptResponse will be demonstrated at the Home Entertainment Show, New York Hilton suite 210 with Dolby Labs, AIX Records, Piega, and Sanibel. It will also be demonstrated at the Home Entertainment Show, room 747 with Brinkman Audio and Marten Design.
Contact: John McDonald, President
john@audience-av.com
760-720-9611
www.audience-av.com
