Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through May 02, 2005 >
Gefen Upgrades Two KVM Extenders for Digital Displays
| Posted by Linda Morgan on Tuesday, April 26, 2005 - 02:26 pm: |
Gefen's new CAT5-1000 HD and CAT5-7000 HD use a sender and receiver methodology connected by cost-effective CAT-5 cables to link the computer to its remote peripherals.
The CAT5-1000 HD supports the extension of one DVI display and USB up to 150 feet from the computer using just one CAT-5 cable.
The CAT5-7000 HD supports the extension of two DVI displays, USB, PS/2, RS-232 and audio plus a microphone up to 150 feet using multiple CAT-5 cables.
"Extending computer equipment beyond the format specifications requires an extension method that will guarantee remote performance, especially with digital video display's higher resolutions," said Hagai Gefen, president. "Our upgraded CAT-5 KVM extenders ensure digital video retains its clarity
and the accompanying peripherals perform remotely with just as much speed as if connected locally."
Gefen's upgraded KVM extenders offer a method of extending the workspace away from the computer without networking. The plug and play system takes minutes to install and requires one 5VDC power supply to feed the system, which can be connected at either end.
The CAT5-1000 HD (http://www.gefen.com/kvm/product.jsp?prod_id=2574) is currently available for purchase online at www.gefen.com or through a Gefen reseller.
The CAT5-7000 HD (http://www.gefen.com/kvm/product.jsp?prod_id=2799) is available for pre-order.
Gefen provides consumer electronics and audio/video connectivity solutions with multi-platform extension, switching, distribution and conversion capabilities. Gefen is consistently the first to deliver advanced technologies for home theater, computers and other AV environments. Products support high definition digital video, analog video and digital and analog
audio using various interfaces such as HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, USB, Firewire and RS-232. A selection of cabling is also available. Additional information may be found at www.gefen.com.
