Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through May 30, 2005 >
New High Definition Video Extender from Gefen Designed Tough for Rental andSt...
New High Definition Video Extender from Gefen Designed Tough for Rental andStaging
| Posted by Linda Morgan on Wednesday, May 25, 2005 - 01:21 pm: |
Though armed with cable connectors that are better able to endure frequent and repetitive setup and take-down procedures, the DVI-1000 ST uses the same methodology to extend high definition digital video up to 500 meters (1640
feet) from source to display. Small sender and receiver units link the source to the extended display with multimode fiber optic cables, available from Gefen in lengths ranging from 33 to 330 feet. The DVI-1000 ST supports high resolutions up to and including 1080p or 1920x1200 for computers, and is equipped with DVI inputs and outputs to connect its sender and receiver
units to the source and the extended display.
"This new version of the DVI-1000 came about in response to feedback from our customers, who were pleased with its video extension capability and performance, but needed more robust cable connectors that could handle repetitive plugging and unplugging," said Hagai Gefen, president. "The new DVI-1000 ST meets this demand."
The DVI-1000 ST is currently available online at www.gefen.com with shipping to begin in June 2005. Demos will be available at booth 108 at InfoComm in Las Vegas, Nevada beginning June 8 through the 10.
http://www.gefen.com/kvm/product.jsp?prod_id=2940
Specifications:
Video Amplifier Bandwidth: 165 MHz
Input Video Signal:1.2 volts p-p
Input DDC Signal: 5 volts p-p (TTL)
DVI Connector: Type DVI-D
Link Connector: RJ-45
Power Supply: 12 VDC
Power Consumption: 15 Watts (max)
Dimensions: 3.25"D x 4.25 "W x 1"H
Shipping Weight: 5 lbs.
About Gefen:
Gefen provides consumer electronics and audio/video connectivity solutions with multi-platform extension, switching, distribution and conversion capabilities. Gefen is consistently the first to deliver advanced technologies for home theater, computers and other AV environments. Products support high definition digital video, analog video and digital and analog
audio using various interfaces such as HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, USB, Firewire and RS-232. A selection of cabling is also available. Additional information may be found at www.gefen.com.
