Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through June 17, 2005 >
Mark Levinson Ships No33H Monaural Power Amplifier
| Posted by Admin on Thursday, June 16, 2005 - 07:17 pm: |
Mark Levinson announces it has begun shipment of the No33H Monaural Power Amplifier. Designed to offer the highest performance possible and continue the rich heritage of the Mark Levinson line, the No33H offers a true balanced input topology, rejecting common mode noise and distortion into the loudspeaker's voice coil. Output voltage is conservatively rated at 34.6V rms @ 8 Ohm and 4 Ohm loads continuously from 20 Hz to 20 kHz with less than 0.3% THD with a frequency range of 20 Hz to 20 kHz within 0.2 dB, equivalent to 150 Watts and 300 Watts respectively.
The No33H provides a separate, isolated power supply for each half of the inverting and non-inverting signal, utilizing four 60,000 µF low-ESR capacitors and a massive 3.47 kVA low-noise toroidal transformer. To further ensure the cleanest possible signal, the No33H has built-in mains regeneration. AC power is rectified into positive and negative DC supplies to power a pure 60 Hz sine wave generator whose output is rectified, filtered and regulated for all voltage gain stages. The No33H also has a built-in 'Link' feature that allows for compatible Mark Levinson preamplifiers and power amplifiers to share 'Link' control. Input and output communication ports can use Link or Link 2. A remote turn-on option is provided with 1/8" input connector accepting 5-12V DC, which in turn feeds a second built-in 1/8" output connector to remotely turn on other equipment, allowing for daisy-chain control.
The Mark Levinson No33H demonstrates the company's ongoing commitment to bringing the best products to market, further solidifying the Mark Levinson name in the hearts of audiophiles. The No33H Monaural Power Amplifier is available immediately from authorized Mark Levinson dealers.
About Mark Levinson
Mark Levinson, established in 1972, has become a world-renowned manufacturer of the finest stereo and home theater electronics. Products range from awe-inspiring monaural power amplifiers to industry benchmark preamps/processors. Mark Levinson audio systems can now also be enjoyed in select Lexus automobiles.
Mark Levinson is a division of Harman International, Inc. Harman International (www.harman.com) is a leading manufacturer of high quality electronics and speakers for the consumer, professional, and OEM markets. The company's stock is traded on the New York Stock Exchange under the symbol HAR.
"Mark Levinson" is a registered trademark of Harman International Industries. U.S. patents and other worldwide patents issued and pending. Other company and product names may be trademarks of the respective companies with which they are associated.
