Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through July 12, 2005 >
Gefen's 1x4 DVI Monitor Switcher Increases HDTV Viewing Options
| Posted by Linda Morgan on Tuesday, June 21, 2005 - 01:08 pm: |
Gefen's new 1x4 DVI Monitor Switcher works in reverse from its traditional switchers, supporting the connection of up to four displays to one high definition video source.
It is designed to switch the video between several monitors for applications commonly used in broadcast, post-production, entertainment, retail, security and educational industries.
Users select which monitor will display the video with an IR remote control. Switching is performed with no down time and high resolutions up to 1080p and 1920x1200 are supported.
Gefen's 1x4 DVI Monitor Switcher is also HDCP (high bandwidth digital content protection) compliant and will pass through high definition video intact.
"We devised this model to augment our growing line of HDTV switchers," said Hagai Gefen, president and CEO. "It seemed the logical next step to support those audio/video systems that need to assign video to specific rooms in the home or office, or in more commercial environments such as post-production."
Gefen's 1x4 DVI Monitor Switcher (MSRP $399) comes equipped with one DVI input, four DVI outputs and one 5v power supply. It is available to order online at www.gefen.com or through an authorized Gefen reseller.
http://www.gefen.com/kvm/product.jsp?prod_id=3033
About Gefen:
Gefen provides consumer electronics and audio/video connectivity solutions with multi-platform extension, switching, distribution and conversion capabilities. Gefen is consistently the first to deliver advanced technologies for home theater, computers and other AV environments. Products support high definition digital video, analog video and digital and analog
audio using various interfaces such as HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, USB, Firewire and RS-232. A selection of cabling is also available. Additional information may be found at www.gefen.com.
