Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through August 02, 2005 >
Atlantic Technology Steps into the Sunlight
| Posted by Gordon Sell ... on Tuesday, July 26, 2005 - 04:28 pm: |
NORWOOD, MASS (7/26/05) -- Atlantic Technology has introduced its first indoor/outdoor speaker, the AW-424.
The new speaker brings a fresh approach to solving the problems associated with conventional outdoor speakers. It utilizes dual 4 1/2-inch woofers flanking a special weather-resistant version of Atlantic's highly-regarded 1-inch soft dome tweeter for the responsiveness and high power handling required for outdoor speakers. The AW-424 is designed for vertical or horizontal mounting. Its woofer-tweeter-woofer configuration provides control over the speaker's dispersion, allowing the sound to be focused on a specific listening area.
"For years, consumers, installers and magazine reviewers alike have given Atlantic Technology products their highest recommendation," comments Atlantic Technology President Peter Tribeman. "Now, for the first time, our customers can take that great Atlantic sound with them outdoors."
Great outdoor acoustic performance is not the only area where the AW-424 displays its merits. The AW-424 employs an ingenious but uncomplicated mounting bracket that simplifies installation significantly. The consumer or installer attaches the bracket to the wall and slides the speaker onto it, using the mounting channels cut into the bracket ears. Simply tightening down the knobs completes installation - no more blind fumbling while teetering on a ladder, trying to locate the hole for the knob in a bracket far above your head.
The terminal well has drainage channels to keep water from collecting around the connections. Four self-adhesive rubber feet are included for customers who opt to use this attractive, high-performance speaker inside on a bookshelf.
The Atlantic Technology AW-424 indoor/outdoor will available at the beginning of August for a suggested price of $399 per pair.
From its inception in 1989, Atlantic Technology's mission has been to produce home entertainment products that exemplify the very best in both performance and value. The company specializes in complete high-performance multi-channel speaker systems, state-of-the-art home theater electronics components, and products for custom audio/video installation. For more information on Atlantic Technology and its many fine products for home theater and custom audio/video installation, visit www.atlantictechnology.com or call 781-762-6300.
For high resolution image files, please visit: http://www.gspr.com/atlantic/aw424.html
