Home > Message Board > Press Releases > Archive through 2008 > Archive through August 02, 2005 > Gefen Extends HD Video with RS-232 Control
CEDIA Booth: 8
WOODLAND HILLS, CA - For years Gefen has been extending high definition digital video hundreds of feet beyond its 3-meter specification. With its new ex-tend-it DVI RS-232 Extender, available at CEDIA, Gefen ups the bonus features and capabilities even more.
First, it sends high definition DVI video up to 30-meters to an extended display over industry-standard CAT-5 cables, cutting the cost of long cable runs. It also enables standard in-home wiring to be tapped into for HD home automation systems.
Secondly, it offers RS-232 inputs/outputs that support the remote control of HD extended video. It sustains HDTV resolutions up to 1080p or 1920x1200 for computers, and supports HDCP (high bandwidth digital content protection)
compliant devices with its sender and receiver format.
Gefen's DVI RS-232 Extender still retains the system sleekness that takes up little space behind the scenes. Sender and receiver are small enough to fit in the palm of a hand, and link local and remote components with two CAT-5 cables. RS-232 signals are sent over the same cables.
The DVI RS-232 Extender (MSRP $599), supports HDMI sources and displays with an optional adapter from Gefen. Detailed information may be found online at Gefen.com where products may be purchased.
http://www.gefen.com/kvm/product.jsp?prod_id=3104
About Gefen:
Gefen delivers consumer electronics and audio/video connectivity solutions with multi-platform extension, switching, distribution and conversion capabilities. Gefen is consistently the first to deliver advanced technologies for home theater, computers and AV environments. Products support high definition digital video, analog video and digital and analog
audio using various interfaces such as HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, USB, Firewire and RS-232. A selection of cabling is also available.
