Home > Message Board > Press Releases > Archive through 2008 > Archive through August 24, 2005 > Gefen 2x1 DVI KVM Switcher Gives Affordable Access to Two Computers from One ...
Gefen 2x1 DVI KVM Switcher Gives Affordable Access to Two Computers from One Digital Display
WOODLAND HLLS, CA - August 18, 2005 - The new Gefen 2x1 DVI KVM Switcher easily connects two cross-platform computers to one keyboard, video display and mouse (KVM) workstation.
It is especially useful for users of Apple Mac mini low-cost computers when combined with another PC or Macintosh computer at the same workstation. This digital KVM solution also allows users to share peripherals between their laptops and desktop computers.
Stereo audio, high speed USB 2.0 and DVI video in resolutions up to 1920x1200 are output for each computer.
Users can select whatever type of USB compatible keyboard and mouse they want for either PC or Macintosh peripherals. All DVI equipped computers and displays can be connected to the 2x1 DVI KVM Switcher.
The 2x1 DVI KVM Switcher, measuring just seven inches wide, two and a half tall and four deep, provides a switch button on the front of the unit that gives access to computer data in just seconds.
One five-volt power supply drives the system and an optional RMT remote can access computers from a distance if needed.
Additional information on the Gefen 2x1 DVI KVM Switcher (MSRP $199) is available at: http://www.gefen.com/kvm/product.jsp?prod_id=3113
About Gefen:
Gefen provides consumer electronics and audio/video connectivity solutions with multi-platform extension, switching, distribution and conversion capabilities. Gefen is consistently the first to deliver advanced technologies for home theater, computers and other AV environments. Products support high definition digital video, analog video and digital and analog audio using various interfaces such as HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, USB, Firewire and RS-232. A selection of cabling is also available. Additional information may be found at www.gefen.com.
