Home > Message Board > Press Releases > Archive through 2008 > Archive through October 12, 2005 > New Gefen DVI Extender Sends Analog and Digital Audio Plus HD Video Up to 150...
New Gefen DVI Extender Sends Analog and Digital Audio Plus HD Video Up to 150 Feet
WOODLAND HILLS, CA – Small in size but big on performance, the new Gefen DVI/Audio CAT5 Extender provides unbeatable options for the extension of high definition audio/video systems.
Whether you aim to use it with a computer or HDTV system, this Gefen extender has got you covered. Computer users will appreciate the fact that it sends DDC controls, digital or analog audio plus DVI video over two industry-standard CAT5 cables. HDTV viewers will applaud its stereo and digital audio support for surround sound.
Small enough to fit in the palm of your hand, the DVI/Audio CAT5 Extender’s footprint sender and receiver units come equipped with DVI, analog audio and S/PDIF ports. Two category-5 cables send everything connected up to 150 feet in distance. A five-volt power supply, which can be connected at either end, feeds the system.
Detailed information may be found at: http://www.gefen.com/kvm/product.jsp?prod_id=3329
The Gefen DVI/Audio CAT5 Extender (MSRP $599) can be purchased online or through an authorized Gefen reseller, also listed online.
About Gefen:
A leader in the high definition digital domain, Gefen delivers advanced technologies with multi-platform extension, switching, distribution and conversion capabilities. Gefen equipment is utilized all over the world in professional AV/IT and consumer electronics/home theater environments. Their add-on hardware maximizes system functionality and enhances operability by enabling AV systems to go beyond their original functionalities. Solutions support an array of connectivity interfaces including HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, RCA, USB, Firewire and RS-232. A selection of high quality cabling is also available. Additional information may be found at www.gefen.com.
