Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through October 12, 2005 >
Scand LLC Releases New Customizable JavaScript Menu for Web Applications
| Posted by Ivan Petrenko on Thursday, October 06, 2005 - 10:11 am: |
Minsk, Belarus, October 6, 2005 -- Software development company Scand released its new product - dhtmlxMenu v1.0. This JavaScript menu enables web developers to design and edit a simple DHTML menu in a very convenient way.
dhtmlxMenu has cross-browser support, so it can be used for sites and web applications that are supposed to run under different OS. The menu is compatible with all main web browsers for Windows, Linux, Unix and Mac OS.
This JavaScript menu has XML support that gives possibility to build menus dynamically from XML file or database. Any complex menu structure can be generated using a simple XML code. Menu appearance can be easily changed dynamically without requiring the web page to be reloaded. Powerful client-side API allows changing the menu state “on-the-fly” with external JavaScript code.
dhtmlxMenu is highly customizable. This JavaScript component provides an easy way to create pop-up or drop down menus of any configuration. dhtmlxMenu can also be used as a right-click context menu.
Skinable design allows web developer to change visual appearance of the menu so it matches different styles, e.g. Windows or Mac OS style. This DHTML menu also has such useful feature as vertical scrolling of items. Above all, the menu has high functional stability and performance.
dhtmlxMenu v1.0 is free for non-commercial use (GNU General Public License - GPL) and can be downloaded from JavaScript Menu Homepage. In order to use dhtmlxMenu in commercial projects, there is a possibility to purchase the Commercial license ($49 – 3 months of support period).
About Scand LLC
Scand LLC is software development company based in Belarus (Eastern Europe). The company delivers offshore outsourcing software development services supplied by the best quality, timeliness and creativity. Scand LLC offers some advanced ready to use Java applets and JavaScript components that are available for download on Scand Website.
Contact Information:
Ivan Petrenko
Scand LLC
Masherova 27
Minsk, Belarus
www.scbr.com
products@scand.com
