Home > Message Board > Press Releases > Archive through 2008 > Archive through October 12, 2005 > INOi HD182 Photo HardDisk 20GB Hard Drive
The Photo HardDisk is the perfect companion for digital photographers as well as mobile computer users. You can easily use this product to back up the most popular type and high-resolution of digital camera flash media.
If you fill up your flash card with pictures and would like to keep shooting. No worry. Just transfer the entire contents of your flash media card to the Photo HardDisk with on one press of a button. Your photos are now safely stored on the internal 1.8" hard disk, allowing you to erase your flash card so you can take more pictures.
Also, the Photo HardDisk can be used with any PC or MAC computer for additional mobile storage of your data files. All your computer need is a USB port. Just plug in the unit and you can quickly upload files to your computer or download to your Photo HardDisk. What¡¦s best is that you don¡¦t even need external power. The Photo HardDisk gets all of its power from your computer, making it a truly mobile device.
