Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through October 25, 2005 >
Digital Foci Introduces "Image Moments" Powerful Digital Photo Album Frame...
| Posted by Karen Thomas on Wednesday, October 19, 2005 - 10:03 am: |
Photos:
http://www.thomas-pr.com/136/photos/digitalfocimomentsphoto.html
http://www.thomas-pr.com/136/photos/digitalfocimomentspackaging.html
http://www.thomas-pr.com/136/photos/digitalfocimomentsside.html
http://www.thomas-pr.com/136/photos/digitalfocimomentsremote.html
Contact:
Karen Thomas
Thomas PR
(631) 549-7575
kthomas@thomas-pr.com http://www.thomas-pr.com
DIGITAL FOCI INTRODUCES “IMAGE MOMENTS”
POWERFUL DIGITAL PHOTO ALBUM FRAME
Displays Photos, Slideshows and Music at Home or Office
Los Angeles, California, October 18, 2005 – Digital Foci, Inc. (www.digitalfoci.com) introduced today the powerful Image Moments digital photo album frame, which lets you display and share photos directly from digital camera memory cards at home or at the office on beautiful maple or walnut picture frames. Just insert any digital camera card into Image Moments and memories will instantly come to life in sharp, vibrant color on its big 8-inch high-resolution LCD screen.
Photo Slideshows with Music
Instead of seeing the same picture day in and day out as you do with traditional print photo frames, Image Moments lets you easily change photos at your whim. Remember cherished memories – your wedding, the birth of your baby, or your family vacations with Image Moment’s “Photo Slideshow Mode,” which lets you automatically scroll through collections of photos. Since Image Moments supports MP3 and video formats, you can even add music to your slideshows and play movies.
Remote Control and On-Screen Display Make Navigation Simple
The full-featured remote control and On-Screen Display let you easily navigate, select, and view your digital photos and videos. Slideshows can be started and stopped and intervals and transitions can be changed with a touch of the remote control. In addition, you can manipulate and see photo detail–- zoom-in for a close-up, rotate or pan, and adjust brightness and RGB color for optimal viewing. Search your memory card contents easily in the “File Library” and browse through photos in “Photo Thumbnail View.” Files can also be sorted by Photo, Music, or Video formats for easy access.
Built-in Memory Card Slots for Multiple Media Formats
With its built-in memory card slots, Image Moments can display photos directly from digital camera memory cards with no subscription or computer needed. Image Moments reads from virtually all cards, including CompactFlash I/II, MD, SmartMedia, MMC, SD Card, Memory Stick, MS PRO, xD-Picture Card, miniSD, and MS Duo. Adapters are required for the xD-Picture Card, miniSD, and MS Duo formats.
Image Moments Features:
• 8” high-resolution LCD screen for digital photo display
• Automatic photo slideshow with music
• Reads directly from memory cards
• Supports memory cards: CF I/II, MD, SM, MMC, SD Card, Memory Stick, MS PRO
(plus mini-SD, MS Duo, MS PRO Duo, and xD-Picture Card with adapter)
• Full-featured remote-control for file navigation and display settings
• Classic wooden frame design
• JPEG image support
• MP3 music support
• MPEG1, MPEG2, and MJPEG video support
Image Moments comes in 2 frame colors: maple and walnut. The classic wooden frame design matches perfectly with living room or office decor. Image Moments comes with an AC power adapter, remote control, detachable leg, video/audio cable, User’s Guide, and Quick Start Guide. It is available immediately at Digital Foci’s online store at www.digitalfoci.com for $299.
Image Moments Spec Sheet
Model no. IMT-080
LCD screen 8" color TFT LCD screen
Screen resolution 640 x 480 pixels (VGA)
Picture aspect ratio 4:3
Brightness 250 cd/m2
Contrast ratio 250:1
Viewing angle 130 degrees horizontal, 110 degrees vertical
Memory card supported CompactFlash I & II, MicroDrive
SmartMedia, xD-Picture Card*
SD Card, miniSD*, MultiMedia Card, RS-MMC*
Memory Stick, MS PRO, MS Duo*, MS PRO Duo*
(* adapter required)
Image format support JPEG
Video format support MPEG1 (352x240@30fps)
MPEG 2 (720x480@30fps)
MJPEG (720x486)
Music format support MP3
Power AC 100-240V, DC 12V/3A power adapter
Dimensions 9.8" (L) x 8.0" (W) x 1.8" (H)
Weight 2.9 lbs
