Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through November 14, 2005 >
DhtmlxTree 1.2 - Efficient Way to Organize Data in Function-Rich Dynamic Tree...
DhtmlxTree 1.2 - Efficient Way to Organize Data in Function-Rich Dynamic Tree View
| Posted by Ivan Petrenko on Wednesday, November 02, 2005 - 06:07 am: |
Minsk, Belarus, November, 2 – Scand LLC is proud to announce the release of its cross-browser JavaScript tree menu dhtmlxTree version 1.2. This DHTML navigation component provides comprehensive solution for displaying hierarchical data in attractive tree view on a web page.
Using AJAX this tree menu can load its content on demand without page reloading, that’s why the component works great with large dataset. Another popular way to manage big trees, implemented into dhtmlxTree starting from v.1.1, is Smart XML parsing, which got some enhancements in v.1.2.
This new version of JavaScript tree brings extended drag-and-drop functionality. Now this feature works not only between trees placed on different frames, but also includes the possibility to drag tree items to other HTML elements on a page. This DHTML tree also provides the ability to copy nodes using drag-and-drop operation.
Version 1.2 of the tree control extends support for customizing the tree behavior by attaching JavaScript functions to different events, including drag and drop operations and loading process. This allows web developer to process user interaction with a web application more efficiently.
dhtmlxTree 1.2 also introduces some improvements in its checkbox system. Now there is an ability to hide or disable checkboxes for certain nodes or set a predefined value for some checkboxes if needed. Earlier introduced three-state checkboxes became Smart XML Parsing compatible and now the third "partly-checked" state can be set with XML.
This new release of the tree control provides enhanced support of various server-side technologies that facilitates easy integration with different web applications. dhtmlxTree 1.2 has Cold Fusion and JSP tags, as well as ASP.net custom control.
In addition, dhtmlxTree version 1.2 brings such new features as: nodes sorting and searching capabilities, changeable icon size, enriched client-side API, increased overall performance, more detailed documentation, new samples, etc. This latest release was tested with all existing standard document types, including XHTML.
dhtmlxTree 1.2 is available in two editions: Standard Edition and Professional Edition. The Standard edition is free for non-commercial use (GNU General Public License - GPL) and can be downloaded from the JavaScript tree page. Professional Edition provides enriched functionality and can be purchased according to Commercial license ($99 per application) or Enterprise license ($399 per unlimited number of applications).
About Scand LLC
Scand LLC is software development company based in Belarus (Eastern Europe). The company delivers offshore outsourcing software development services supplied by the best quality, timeliness and creativity. Scand LLC offers some advanced ready to use Java applets and JavaScript components that are available for download on Scand Website.
