Home > Message Board > Press Releases > Archive through 2008 > Archive through December 05, 2005 > New Software Released: Latest PDF Converter from PDF-File.com Converts PDF to...
New Software Released: Latest PDF Converter from PDF-File.com Converts PDF to Word and Makes PDF Files
Summary:A new PDF converter has just been released by Nooran Corp. of Canada, named after their site PDF-File.com. This PDF converter is the second offering from this Canadian software firm.
Ontario, Canada. – Nov. 2005
The latest PDF converter has just hit the PDF space in the form of PDF-File PDF Converter. This is another quality offering by Nooran Corp., a software firm based in Canada. The firm has named this PDF conversion tool after the website PDF-File.com, from which the software is being sold. Nooran Corp. had also launched a software utility recently by the name of 123FileConvert.
The PDF-File PDF Converter has multi-function capability: it can convert a PDF file to a Word document, and a .doc or .rtf document can be converted into a PDF file. So you can make your PDF files editable by changing them into one of the popular text formats, and also create or “write” a PDF file from these text formats. You don’t have to worry about losing the formatting of the source document as the software handles this very well.
This PDF converter is an easy-to-use tool, which does not need any special technical skills to operate. It has a “wizard” style interface, which guides you step-by-step through the PDF conversion process. This PDF tool is therefore, one of the easiest in its segment to use.
In addition to being easy to use, the PDF-File Converter comes with a lot of features, which are surprisingly being offered at a very low price of $19.95.
The PDF-File converter, apart from the basic function of converting to a PDF and from a PDF, can also extract images from PDFs, and further, convert these images to popular graphic formats; this feature is particularly useful as you can extract graphic files from any PDF file to a specific folder in the format that you want.
The PDF-File Converter has multi-lingual PDF conversion capability and it can convert PDF files in nine languages--English, Italian, Spanish, Dutch, French, Russian, Norwegian, Portuguese and German.
Multiple text files can also be combined to create a consolidated PDF file. A PDF can also be partially converted by specifying a page range for conversion.
This is one PDF converter, which has collected a lot of favorable reviews and awards from software and shareware sites very fast. If you wish to try it out, the PDF-File PDF Converter can be downloaded free for an evaluation from http://www.pdf-file.com.
About the company: Nooran Corp. is a software development firm based in Markham. Ontario. Canada, which specializes in developing and marketing useful software utilities. Nooran Corp. also develops custom software applications for its clients. Please visit PDF-File PDF Converter to contact Nooran Corp.
