Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through December 05, 2005 >
Gefen Releases 4x1 HDMI Switcher for Enhanced Performance
| Posted by linda morgan on Wednesday, November 30, 2005 - 11:41 am: |
The Gefen 4x1 HDMI Switcher performs a valuable role in the connection of multiple components to a single input HDTV display. It enables up to four HD sources to be accessed from the same HD display.
The ability to add DVI sources such as computers (with an optional HDMI to DVI Adapter), and control from an RS-232 interface or IR remote helps make this product shine.
Based on customer feedback, the 4x1 HDMI Switcher is now available in black to better blend with system components and room aesthetics, in addition to the traditional silver/blue.
“Offering different color and weighting the box to better balance its stance was an easy change to implement, and we are already seeing increased interest in the new color option,” said Hagai Gefen, president and CEO.
Measuring approximately 11 inches long by one and a half tall, the unit has been slightly weighted to prevent the box from lifting by the weight of the four HDMI cables on its backside.
HDMI compliant, high definition video up to 1080p resolution is supported and the unit passes through HDCP compliant signals from the sources through the switcher to the display.
The 4x1 HDMI Switcher (MSRP $399) is currently available to order online at Gefen.com or through an authorized Gefen reseller, also listed online.
About Gefen:
A leader in the high definition digital domain, Gefen delivers advanced technologies with multi-platform extension, switching, distribution and conversion capabilities. Gefen equipment is utilized all over the world in professional AV/IT and consumer electronics/home theater environments. Their add-on hardware maximizes system functionality and enhances operability by enabling AV systems to go beyond their original functionalities. Solutions support an array of connectivity interfaces including HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, RCA, USB, Firewire and RS-232. A selection of high quality cabling is also available. Additional information may be found at www.gefen.com.
