Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through December 27, 2005 >
Astroflex introduces remote starter with ultra compact remote
| Posted by WIRC Media T... on Tuesday, December 06, 2005 - 11:52 am: |
November 28th, 2005Astroflex (www.astroflex.com) has announced the introduction of the Model 701XR remote start system, designed to overcome objections from consumers whose factory keyless entry buttons are built into their ignition key assembly. Such factory keys are typically quite large, and many consumers are unwilling to add yet another sizable remote device to their already bulky key chain. The AstroStart 701XR delivers the luxury and convenience of remote start capability utilizing a tiny, single-button remote control that adds little bulk or weight to the key ring. The Model 701XR has an outstanding remote transmit range of 2000-feet, thanks to the innovative Astroflex SAW receiver technology that utilizes a high-sensitivity pre-amplifier. The Model 701XRs single button controls engine start/stop and Continuous Mode, which allows the motorist to leave the car fully locked and protected while the engine is running. The 701XR is also diesel engine and standard transmission compatible utilizing AstroStart interface modules.
Outstanding transmission range of 2000 feet
Remote uses ultra-bright LED for transmission confirmation visible even in daylight
Remote powered by Lithium battery for best cold weather performance
1 easy-to-use, 1-button one-way transmitter with LED light and more than 4 billion different codes
Superheterodyne SAW receiver (Surface Acoustic Wave) and invisible polyester antenna
Control module with RISC (Reduced Instruction Set Core) microprocessor
4-way protection against theft when vehicle is remote started: gas pedal, brakes, hood and main switch
Diagnostic mode allowing installer to determine nature of violation or engine stop (LED or Multitest II)
Command reception acknowledgment via parking lights
Negative input for engine start using another accessory (timer)
Integrated programmable relay
About Astroflex: Astroflex has been designing and manufacturing remote devices in Canada since 1989. Dealers and consumers have realized the tremendous benefits associated with the integration of R & D, production, tech and sales support all under one roof. AstroStart systems are currently the only North American made remote start systems available. The US market is served by a sales and distribution center in Manchester, NH. Astroflex provides extensive installer training in addition to a high level of support through innovative tools such as the AstroChart installer software and the MultiTest II proprietary programming and diagnostic device. Astroflex is dedicated to bringing best quality manufacturing and innovative design to the remote devices category.
Astroflex expects to be shipping the 701XR remote starter by December 15th, 2005. Please direct press inquiries to:
Media contact:
Micah Sheveloff
WIRC Media Tactics
203-795-3141
wirc1@earthlink.net
