Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through December 27, 2005 >
ProMounts to Exhibit new UF PRO Mount at CES.
| Posted by Al Abrams on Thursday, December 22, 2005 - 01:34 am: |
Plasma/LCD Mount With V-BAR Technology at CES Booth 21661
December 21, 2005 – Culver City, CA – ProMounts, Inc. will exhibit its UF-PRO mount with the unique built-in V-BAR technology in Booth 21661 at CES, 2006 in Las Vegas.
The ultra-flush, universal design UF-PRO allows vertical and horizontal adjustment of a monitor after installation, and fits over 95% of current flat plasma and LCD screens made today, including most 37" to 60" screens.
“We designed the UF-PRO mounts with the needs of the installer and the consumer in mind,” said Larry LaCross, VP Sales and Marketing for ProMounts. “The UF-PRO is not only the thinnest, flattest universal mount available; it’s the most versatile flush mount in the market, measuring only 0.98" from the wall, with up to 3" of vertical adjustment available after initial installation.“
The UF-PRO features unmatched durability and ample space for wire management to make installation of the mount a snap. The new UF-PRO is manufactured from high quality, heavy gauge steel construction that supports up to 175 lbs.
“The UF-PRO is easy to put up and very easy to use, “ added LaCross. “And for the retailer, they’re easy to sell. With every mount we make, we provide new, colorful, eye-catching packaging and in-depth installation videos.”
The UF-PRO is available in either a black or silver finish, with only three main parts needed for easy installation. All necessary hardware is included for different wall types. Horizontal and vertical position adjustments allow perfect positioning of the screen regardless of the distance of wall studs. Mounting hardware and theft-resistant security fasteners are included. Digital images are available at www.promounts.com.
Suggested retail price is $199.00
ProMounts is located at 5741 Buckingham Way, Unit C, Culver City, CA 90230,
Tel: 310-645-6400, Fax: 310-868-2751, email: info@promounts.com. PR and media contact is Al Abrams, Abrams Creative, 818-343.6365, Fax: 818-343-6366, e-mail: abrams@publicist.com.
Promounts - CES UF PRO release (33.3 k) |
