Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through February 23, 2006 >
New Gefen Component Video Extender Sends HD Video Up To 300-Feet
| Posted by Linda Morgan on Friday, February 17, 2006 - 09:13 am: |
The system enables DVD players, satellite television set-top boxes or any video device equipped with RGB connectors to be extended up to 300 feet from the display over a single CAT-5 cable.
HD video may be viewed at up to 1080p resolutions, allowing modern and legacy equipment to support the pristine delivery of HD video even when extended hundreds of feet.
System hardware includes tiny sender and receiver units, both small enough to be tucked away inconspicuously behind the scenes. Both units are painted black to blend with system aesthetics and run on a single power supply (included).
Sender and receiver come equipped with VGA and CAT-5 ports; a six-foot high quality VGA to RGB cable is included for component connection.
Installation is plug and play, requiring a simple connection of the system to the video source and the extended display that anyone can easily implement.
Additional information on Gefen’s Component Video Extender (MSRP $299) may be found at:
http://www.gefen.com/kvm/product.jsp?prod_id=3414
About Gefen:
A leader in the high definition digital domain, Gefen delivers advanced technologies with multi-platform extension, switching, distribution and conversion capabilities. Gefen equipment is utilized all over the world in professional AV/IT and consumer electronics/home theater environments. Their add-on hardware maximizes system functionality and enhances operability by enabling AV systems to go beyond their original functionalities. Solutions support an array of connectivity interfaces including HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, RCA, USB, Firewire and RS-232. A selection of high quality cabling is also available. Additional information may be found at www.gefen.com.
