Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through March 06, 2006 >
Gitzo Develops Breakthrough Carbon Fiber Technology
| Posted by Andrew Cefalo on Wednesday, March 01, 2006 - 10:48 am: |
Backing Gitzo 6X technology is the new six-crossed multilayer range which features the Anti Leg Rotation (ALR) system. The ALR system allows for a fast and smooth setup, yet maintains the uncompromised locking strength of the traditional Gitzo twist lock system. Just loosen all twist locks at the same time and pull down the leg before tightening them, making setup a mere 15 seconds for this five sectioned tripod.
The existing 1.5mm Gitzo carbon fiber tube wowed the world with its unsurpassed strength, stability and remarkable lightweight form factor. Utilizing a three-crossed multilayer carbon structure, bonded together at high pressure and temperature by high quality resins, Gitzo was able to offer professionals a carbon fiber tube that proved to be the ultimate in vibration absorption, strength and stability.
With an eye on advancing its 1.5mm tube and taking it to the next level, Gitzo set out to reduce the weight of the tube even further; however, its R&D team was challenged to do so without sacrificing the strength and stability that the 1.5mm was known for.
Tapping into its revolutionary resources and utilizing its unmatched experience with composite materials, Gitzo was able to develop a new, six-crossed multilayer carbon fiber 30 percent lighter than the previous generation that features the same exceptional performance of stability and vibration absorption and unbeatable quality.
Common knowledge suggests that in order to go lighter you have to go thinner; however, reducing the size of the already thin 1.5mm tube would inevitably result in a loss of strength. By fine tuning its market leading three layer technology to a six layer, with advanced parameters in terms of pressure, temperature and bonding resins, Gitzo was able to beat the odds and create the 6X generation. The six-crossed multilayer tubes measure only 1mm, but are equally as strong and as stable as the 1.5mm, three layer carbon fiber tubes. The 6X range represents, once again, Gitzo leadership not only in introducing unique and world-first innovations, but above all in creating the best products in terms of quality and performances.
In addition to the new, exclusive six-crossed multilayer structure tube and the Anti Leg Rotation System, the new 6X carbon fiber tripods have been further improved to achieve an even higher quality standard. In a world where details matter, even the smallest details on these tripods have been improved. Top casting now features high quality corrosion resistant, polished stainless top casting bolts for added stability and a redesigned built-in, spring-loaded retractable hook on the bottom of the center column provides a place to hang a stabilizing counterweight such as camera, sand or water bags.
Gitzo products are distributed exclusively by Bogen Imaging in the United States. For information, contact Bogen Imaging at info@bogenimaging.com or (201) 818-9500.
Additional information and hi-res images are available by accessing the Bogen Imaging Press Room at: www.bogenimaging.us
About Gitzo:
Professionals the world over acknowledge Gitzo tripods, monopods, heads and accessories as setting the industry’s standards for excellence. Innovations such as the first uses of carbon and basalt fiber to make tripods and magnesium to make heads, matched with a design policy of “no gimmicks and no compromise on quality,” put Gitzo products in a class of their own. Gitzo’s carefully crafted products form a comprehensive range of supports for large, medium and small format cameras, for film or digital technology, for still photography or dynamic video, for studio or location work. Precision assembly, high quality materials and fine control are all qualities that represent Gitzo products.
About Bogen Imaging:
Since 1959, Bogen Imaging (formerly Bogen Photo) has been a leading source for photographic, cinematic and video lighting, supports, and accessories. Many of the most respected manufacturers of precision products for the photographic, video, Cine and lighting are distributed in the U.S. exclusively by Bogen. These include Manfrotto and Gitzo tripods and heads, Kata protective carrying systems and accessories, Avenger lighting grip, I.F.F. ceiling mounted lighting suspension, Metz on-camera flash systems, Gossen light meters, Elinchrom studio lighting systems and a wide host of additional product lines which round out the most complete range of exceptional accessories in the business.
For more information contact:
Bogen Imaging Inc., 565 East Crescent Ave.
Ramsey, NJ 07446
Phone: (201) 818-9500
Fax: (201) 818-9177
e-mail: info@bogenimaging.com
Web: www.bogenimaging.us
Media Contacts:
Jason Ledder or
Melissa Aiello
R&J Public Relations, LLC
jledder@randjpr.com
maiello@randjpr.com
Larry White, Communications Manager
Bogen Imaging Inc.
(201) 818-9500 x-270
larry.white@bogenimaging.com
