Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through May 16, 2006 >
How to convert QuickTime M4V to MPEG, M4V to AVI and M4V to DVD(*.VOB) ?...
| Posted by David Jackson on Thursday, April 27, 2006 - 05:15 am: |
Introduction of this QuickTime M4V converter
This QuickTime M4V converter is a QuickTime M4V to AVI, QuickTime M4V to DVD(*.VOB) and QuickTime M4V to MPEG converter to convert QuickTime M4V to MPEG, convert QuickTime M4V to AVI. The QuickTime Converter can help you convert QuickTime MOV, QT, MP4, M4V files to AVI, DivX, Xvid, MPEG1, MPEG2, VCD, SVCD, DVD(*.VOB) files.
With the fast and powerful QuickTime video decoder inside, Ultra QuickTime Converter can support almost all MOV, QT, MP4, M4V files, even QuickTime Player has not been installed.
The main features include:
Batch convert MOV, QT, MP4, M4V files to various format files;
NTSC/PAL setting options for DVD, VCD, SVCD exporting;
Change the video bitrate, audio bitrate, framerate, image size etc as you like.
Very user-friendly interface and easy to use.
Very quick in conversion speed and no quality is lost!
Key Features:
Supports MOV, QT, MP4, M4V formats to AVI, DivX, Xvid Supports MOV, QT, MP4, M4V formats to MPEG1, MPEG2
Supports MOV, QT, MP4, M4V formats to VCD,SVCD,DVD(PAL,NTSC)
Do not need install QuickTime Playerr
Multi-task batch execute function
Supports Drag and Drop quciktime files from Windows Explorer
Support large video file, even large then 2GB
Very fast and without any quality loss
Very User-friendly interface
Step-by-step Guide:How to convert QuickTime M4V to MPEG, M4V to AVI and M4V to DVD(*.VOB) with this QuickTime M4V converter?(Take converting QuickTime M4V to AVI for example)
Step 1: Free download this QuickTime M4V converter from http://www.sharewareguide.net/downloadit.php?pd_id=3707 and save it in your computer, and then run it.
Step 2: Launch this QuickTime M4V converter and you will find the user interface simple and easy-to-use.
Step 3: Click "Add Files" button to select QuickTime M4V file as input file.
Step 4: Click "Change" button to select a path for the AVI outputed file, Or you can don't take any operation and use the default path.
Step 5: Click "Output Format" combo-box to select AVI as the outputed file.
Step 6: Click "Convert" button to start to convert QuickTime M4V to AVI.
OK. You successfully compelete to convert QuickTime M4V file to AVI with the QuickTime M4V converter.
I use this powerful and professional QuickTime M4V converter to convert QuickTime M4V file to AVI with perfect quality and fast speed. And we can convert QuickTime M4V to MPEG, M4V to AVI and M4V to DVD(*.VOB) and convert all QuickTime files MOV, QT, MP4, M4V files to AVI, DivX, Xvid, MPEG1, MPEG2, VCD, SVCD, DVD(*.VOB) files. I like this software and would like to share it with you.
