Home > Message Board > Press Releases > Archive through 2008 > Archive through May 16, 2006 > New Adapters from Gefen Link DVI/Digital Audio and Component Sources to HDMI ...
New Adapters from Gefen Link DVI/Digital Audio and Component Sources to HDMI Displays
WOODLAND HILLS, CA - The various audio/video interfaces on most of today's HDTV sources and displays do not always connect easily to each another. DVI, for example, doesn't transmit audio with its high definition resolutions up to 1920x1200 (1080p) though HDMI does.
The DVI Audio to HDMI Adapter from Gefen allows you to send HD video to the display with digital audio in TOSlink and S/PDIF formats. The Adapter comes equipped with one DVI, one TOSlink and one S/PDIF input. The HDMI display and audio receiver connect to the unit's digital outputs. Installation is plug and play with the unit running on its own 5v power supply.
The Component Audio to HDMI Adapter is a unique device that connects component sources or VGA computers to an HDMI display, patching HD video together with two channels of audio (left and right) to the HDMI display. This offers the most convenient method of linking an analog device to a digital display while maintaining the highest HD video resolutions up to 1080p.
Both Adapters are designed to provide a simple technique for linking incompatible interfaces without additional software or networking.
Additional information and specifications for the DVI Audio Adapter ($299) and the Component Audio to HDMI Adapter ($199) are available online at Gefen.com.
About Gefen:
A leader in the high definition digital domain, Gefen delivers advanced technologies with multi-platform extension, switching, distribution and conversion capabilities. Gefen equipment is utilized all over the world in professional AV/IT and consumer electronics/home theater environments. Their add-on hardware maximizes system functionality by enabling AV systems to go beyond their original capabilities. Additional information may be found at www.gefen.com.
