Home > Message Board > Press Releases > Archive through 2008 > Archive through June 08, 2006 > New 42-Inch Flat Panel Ceiling Mount From Peerless Industries
Media Contacts:
Viktorya Maryan
708-865-2110 ext 324
847-721-1651
vmaryan@peerlessmounts.com
PEERLESS INDUSTRIES’ NEW 42-INCH FLAT PANEL CEILING MOUNT READY FOR DIGITAL CONTENT DISPLAY IN RETAIL LOCATIONS
- Features Minimum Parts, Quick and Easy Installation and Clean Appearance -
CHICAGO, IL –May 17, 2006 – Peerless Industries, Inc., the industry leader in professional-grade audio/visual mounting solutions, today introduced its new 42” Flat Panel TV Ceiling Mount for digital signage in retail locations.
Designed specifically for digital content such as product promotion or video demonstrations, the 42” Flat Panel TV Ceiling Mount integrates all required components with minimum parts. It reduces total installation time and allows for rapid completion of large multi-site installations quickly and efficiently. It provides a clean look and comprehensive safety features, making it ideal for displaying digital content in retail environments.
Decorative and Secure Installation Made Quick and Easy
In addition to its low number of independent parts, the mount comes with ‘Quick-Connect’ pins that snap into place, enabling easy and fast one-person installation. The decorative cover surrounds the back of the installation provides a clean look that conceals and secures all components and cables. The mount is UL listed and is seismically tested to assure safety in retail locations.
“This new 42-inch Flat Panel Display Mount is one of a kind in the market. We have designed it with minimal parts so it mounts easily and efficiently, and provides a clean look in any environment,” said Dale Smith, Director of Business Development. “To ensure its safe use in all locations, we’ve completed comprehensive testing including a seismic review on this flat panel TV ceiling mount and can guarantee its secure use in a wide variety of commercial applications.”
Versatile Installation And Simple Screen Adjustability
The 42” Flat Panel TV Ceiling Mount ensures optimal flat panel TV placement in retail environments. It can be mounted to various ceiling surfaces at different heights, depending on location requirements. Screen positioning can be easily adjusted with the mount’s swivel feature with in-place locking. Installers simply set the mount’s Return-to-Zero™ feature to prevent any misalignment of the flat panel TV. If accidental movement or bumping occurs the Return-to-Zero mechanism will automatically re-orient the mount to its original position, eliminating the time required to perfectly re-align the screen.
Availability and Pricing
The 42” Flat Panel TV Ceiling Mount will be available June at an approximate price of $500.00 depending on final design, features and quantities. For more information about Peerless’ mounting solutions for digital signage, visit www.peerlessmounts.com or call (800) 865-2112 ext. 331.
About Peerless Industries, Inc.
Peerless has designed and manufactured the most comprehensive line of audio/visual mounting solutions for over 40 years. Today, Peerless designs and manufactures mounts for current and emerging visual display technologies, including LCD and plasma flat panel displays, projectors, CRT televisions and other electronic equipment used in the commercial and consumer markets. Built on decades of experience and proven expertise, Peerless Industries is ISO 9001 certified and is an approved Underwriters Laboratories testing site. For more information, visit www.peerlessmounts.com
©2006 Peerless Industries, Inc., All rights reserved
All other brands, product names and taglines are trademarks or registered trademarks of their respective owners.
