Home > Message Board > Press Releases > Archive through 2008 > Archive through June 08, 2006 > Peerless’ New Truly Universal Projector Enclouser
CHICAGO, IL – June 7, 2006 – Peerless Industries, Inc., the industry leader in professional-grade
audio/visual mounting solutions, today introduced its new PE1120 projector enclosure for public
environments such as school gymnasiums, stadiums and indoor activity centers.
The PE1120’s solid steel enclosure provides maximum security and is designed to be easily retrofitted
to any mount, protecting the projector from theft and physical damage. Its wrap-around design and
‘Hook-n-Hang’ frame enable easy one-person installation and projector maintenance. The PE1120
will be shown for the first time in the Peerless Industries booth, number 3135, at InfoComm 2006 in
Orlando.
“Physical protection is a critical requirement in high-traffic locations with low-security,” said Derrik
Lam, director, mounting solutions at Peerless Industries, Inc. “This new projector enclosure protects
the projector from damage and provides a clear deterrent in public locations.”
PE1120 Delivers Security and Projector Safety
The new all-steel PE1120 projector enclosure features a floating steel bar design. This design allows
the bars to rotate in place, making it virtually impossible to remove the projector without the proper
tools. Maximum security is supported by the use of Peerless’ patented Penta-Pin™ security fasteners
and a padlock option. The steel construction prevents damage to the projector that may be caused by
3215 W. North Avenue
Melrose Park, IL 60160 USA
(708) 865-8870 • Fax (708) 865-0760
www.peerlessmounts.com
accidental bumping in low ceiling applications or by flying objects, such as basketballs, in a school
fitness facility.
Ease of Installation and Maintenance with Truly Universal Compatibility
The PE1120’s wraparound design enables easy installation for existing projectors without disturbing
the set projector alignment, making it ideal for retrofitting any projector mount on the market. The
hands-free ‘Hook-n-Hang’ frame permits access to the projector without the need to remove the entire
enclosure or to hold the enclosure during maintenance. Users simply disengage the security fasteners,
lower the bottom half and let it hang, leaving both hands free for projector maintenance.
Availability and Pricing
The new PE1120 will be available June at a list price of $369 and comes in black or white. For more
information about Peerless’ mounting solutions visit www.peerlessmounts.com or call (800) 865-
2112.
About Peerless Industries, Inc.
Peerless has designed and manufactured the most comprehensive line of audio/visual mounting
solutions for over 40 years. Today, Peerless designs and manufactures mounts for current and
emerging visual display technologies, including LCD and plasma flat panel displays, projectors, CRT
televisions and other electronic equipment used in the commercial and consumer markets. Built on
decades of experience and proven expertise, Peerless Industries is ISO 9001 certified and is an
approved Underwriters Laboratories testing site. For more information, visit
©2006 Peerless Industries, Inc., All rights reserved
All other brands, product names and taglines are trademarks or registered trademarks of their respective owners.
