Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through August 31, 2006 >
TRIBUTARIES® Debuts Custom Installation Wall-Plate System
| Posted by Nicoll Publi... on Thursday, August 17, 2006 - 10:46 am: |
Orlando, FL—August 15, 2006—TRIBUTARIES® Cable, an established leader in wire and cabling for high-performance home theater and audio/video systems, is debuting an innovative, inventory-efficient concept in installation cabling hardware. The Florida firm’s new Totally Modular Connector Insert System allows custom installers to cut down dramatically on small-parts inventory and jobsite complications, while maintaining the very high quality and reliability of connections and terminations for which Tributaries is known.
Formerly, preparing installers for any combination of RF/cable/satellite, audio, and video connector-termination work in any of just the four commonest housing colors (white, ivory, almond, black), required, at a minimum, no fewer than 64 separate component items at a minimum. But now, Tributaries’ Totally Modular system strips this down to just twelve inventory items, dramatically reducing capital-tie-up, storage, and install complexity.
The Totally Modular concept breaks down wall-plate install elements into three basic units: connectors (gold- or nickel-plated); connector-housings (white, almond, ivory, or black), and standard or Decora™ wall plates, (standard in the same four colors, Decora in ivory or white only), each in a range of openings and/or single or dual-gang layouts.
Totally Modular elements assemble rapidly and easily, using installers’ existing, standard-format crimping and stripping tools—and each terminal accepts a colored-coded O-ring, available in a broad range of hues, to identify and track functions, feeds, or channels.
The installers simply preps the wire or cable, crimps on the color-coded connector housing, the connector itself, and then snaps together connector-housing, and wall-plate to form a finished termination, frequently in under a minute.
Totally Modular Connectors: RG6, RG59; F-type (gold- or nickel-plated); RCA: (gold- or nickel-plated) accepts color-coded O-rings; BNC: (gold- or nickel-plated) accepts color-coded O-rings
Totally Modular Connector Housings: White, Almond, Ivory, Black.
Totally Modular Standard Wall Plates: Almond, Black, Ivory, White, in single, double, triple, quad and hex openings
Totally Modular Decora Wall Plates (two-part, frame + insert): Ivory, White in single-gang and dual-gang; single-, double-, triple-, and quad-openings.
All components of Tributaries’ Totally Modular Connector Insert System are available immediately.
About TRIBUTARIES®
Established in 1991 in Orlando, Florida, TRIBUTARIES® Cable is an acknowledged leader in the design, production and distribution of high-quality audio and video interconnect cables, speaker wires and electronics. The company prides itself on its customer service, and has won the CE Industry magazine “Inside Track” Supplier Loyalty Awards a total of nine times in the past ten years.
TRIBUTARIES® Cable is a wholly owned subsidiary of Gordon J. Gow Technologies, Inc.
For more information about TRIBUTARIES® Cable, please visit www.tributariescable.com.
