Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through August 31, 2006 >
New Speaker Mount Solutions for Fixed, Tilt and Swing Arm Mounts
| Posted by Kim Klietz on Thursday, August 17, 2006 - 04:48 pm: |
PAC300 Side Speaker Adapter
Easily attach speakers to the sides of your Chief large flat panel mount with the PAC300 Side Speaker Adapter. The bracket offers 2” of speaker adjustment, moving up to 1” up and down in ½” increments. Be sure the added weight of the bracket (10 lbs) and speakers doesn’t exceed the weight capacity of the large flat panel mount.
PAC301 Center Channel Speaker Adapter
The PAC301 Center Channel Speaker Adapter allows a center channel speaker to be used with the large flat panel mount. The adapter attaches conveniently between the plasma and the wall mount and includes 5” of height adjustment for different size speakers. It can be used in conjunction with Chief’s PAC300 Side Speaker Adapter for further customization. Be sure the added weight of the bracket (20 lbs) and speaker doesn’t exceed the weight capacity of the large flat panel mount.
PACY1/PACY2/PACA1 Center Channel Speaker Adapters
The PACY1, PACY2 and PACA1 Speaker Adapters attach conveniently between the display and wall mount and provide height adjustment for a perfect fit. The adapters can be used with most Chief Large Flat Panel solutions. The PACY1 is compatible with the Yamaha YSP-1 or Yamaha YSP-100 Digital Sound Projectors, and the PACY2 is compatible with the Yamaha YSP-800. The PACA1 can be used with Atlantic Technology new FS-400 Front Stage Loudspeaker. Be sure the added weight of the bracket (10 lbs) and speaker doesn’t exceed the weight capacity of the large flat panel mount.
Visit Chief at CEDIA Booth #534
About Chief
Chief Manufacturing, a division of CSAV – Chief Sanus Audio Visual, has more than 28 years of proven product and service excellence. Committed to responding to industry needs in the Pro AV, Residential and Office markets, Chief offers a complete line of mounts, lifts and accessories for flat panel TVs and projectors.
Chief continues to design innovative mounting solutions that complement the technology they support. With multiple product awards and patented designs, Chief provides unique mount features, and is recognized for delivering not only quality products, but knowledgeable, helpful customer service.
U.S. and Europe sales offices support a global network spanning the Americas, Europe, the Pacific Rim and beyond. Chief distribution centers are located in Minnesota and the Netherlands. www.chiefmfg.com.
