Universal Dual-Arm Articulating Wall Mount
| Posted by Viktorya Maryan on Friday, September 01, 2006 - 01:21 pm: |
Share |
Create New |
Reply
| Edit
The New PLAV70-UNL supports virtually any 42-inch to 71-inch flat panel screen. Its ability to articulate a large flat panel out over 2-1/2 feet combined with 15-degrees of tilt and 10-degrees of roll adjustment provides impressive functionality for various applications. The vertical screen adjustment feature makes it an ideal mounting solution for recessed installations allowing the installer to raise and lower the screen after installation. The new cord management snap covers guide and conceal signal and power cables quickly and easily for a clean look. It is UL listed to ensure a safe mounting solution. For more information about this or other products within the new PLA articulating mount line visit
www.peerlessmounts.com or call (800) 865-2112.
