Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through September 12, 2006 >
Klipsch Launches New In-Wall Subwoofer With Dedicated Amp
| Posted by Sarah Knight on Thursday, September 07, 2006 - 03:18 pm: |
INDIANAPOLIS (September 7, 2006) — In response to installer demand for a powerful subwoofer system that delivers deep-driving bass without taking up valuable floor space, Klipsch will begin shipping its new in-wall subwoofer with matching rack mountable amplifier this month.
Fitting standard 2- by 4-inch construction, the easy-to-install RW-5802 in-wall subwoofer can accommodate any new or existing structure with a minimum 0.5-inch dry wall surface. Because it features an MDF baffle with a reinforced composite sealed enclosure, this high-powered, passive module subwoofer provides guaranteed performance and minimizes sound transfer into adjacent rooms.
The enclosure houses dual 8-inch long-throw woofers. These exclusive drivers feature stiff, well-damped Cerametallic™ cones, a specially treated aluminum that has been anodized, or electrochemically transformed into ceramic on both outer surfaces. Second only to diamond in strength, this ceramic compound allows the woofers to move at high speeds without blurring the sound like conventional designs.
While the dedicated RSA-500 subwoofer amplifier was primarily designed for use with the RW-5802, it also features custom settings for Klipsch’s AW-800-SW outdoor subwoofer. This high-powered device can drive up to two of these subwoofer modules and delivers 300 watts into an 8-ohm load (one subwoofer module) and 500 watts into a 4-ohm load (two subwoofer modules).
To keep end users from inadvertently tampering with performance levels, the majority of the RSA-500’s controls are housed on its rear panel. A detachable IEC power cord allows for the simple removal and reinstallation of the entire amplifier unit. The RSA-500 was also designed to “play nice” by offering standard input/output connectivity that will support any type of system.
While the RW-5802 and RSA-500 are sold separately, they must be used in conjunction with one another. Available through the residential contracting channel, the RW-5802 subwoofer retails for $500 each (U.S. MSRP) and the RSA-500 amplifier retails for $750 each (U.S. MSRP).
About Klipsch Audio Technologies
Klipsch Audio Technologies, a wholly owned division of the Klipsch Group, Inc., is a leading global manufacturer of high-performance loudspeakers and other entertainment products for the consumer and professional markets. Established in 1946, Klipsch celebrates its 60th anniversary this year, and continues its legacy of developing products that utilize unique, proprietary horn-loaded technology to create the most engaging, emotional and dynamic entertainment experiences. Acquired from company founder Paul W. Klipsch by Fred S. Klipsch and Judy L. Klipsch in 1989, Klipsch has worldwide headquarters and Audio Engineering and Technology Center in Indianapolis; European headquarters and a distribution center in s’Heerenberg, Netherlands; manufacturing facilities in Hope, Ark; and distribution centers in Buena Park, Calif.; Toronto, Canada; and Shen Zhen China. For more information, please visit www.klipsch.com.
SOURCE: Klipsch Audio Technologies
CONTACT: Sarah Knight of Klipsch Audio Technologies, 317-860-8737 or sarah.knight@klipsch.com
PHOTOS: High-resolution, publication-quality images of the RW-5802 and RSA-500 are available for download in the news center at klipsch.com or via e-mail upon request.
WEB SITE: www.klipsch.com
