Home > Message Board > Press Releases > Archive through 2008 > Archive through September 12, 2006 > Two New Switchers from Gefen Offer Sophisticated HDTV Integration with Serial...
Two New Switchers from Gefen Offer Sophisticated HDTV Integration with Serial Communications Control
WOODLAND HILLS, CA -- Gefen continues to build on the success of its high definition video switchers, offering a new 8x1 DVI Switcher and enhanced 4x1 HDTV Switcher for multiple source integration.
Featuring plug and play capabilities, both switchers enable users to access multiple high definition computers and sources using just one input on any high definition display.
The 8x1 DVI Switcher comes in a rack mountable case, providing eight DVI inputs and one DVI output. This enables multiple high definition audio/video sources, such as HD DVD players and computer systems, to be accessed using the single DVI connector on any HD display.
Users access their preferred source using the IR remote that comes with the unit or through the RS-232 port, allowing for serial communications system integration and control. Each source is capable of sustaining high definition video in resolutions up to 1080p or 1920x1200 offering a robust visual experience.
The 4x1 HDTV Switcher offers enhanced features, such as local switching on the unit plus RS-232 and IR remote control. The compact box comes with four DVI inputs and one DVI output.
The unit supports computer systems, DVD players and satellite set top boxes equipped with DVI. This allows computers and electronics devices to be integrated seamlessly and viewed interchangeably using the same DVI port on an HDTV display.
Both of these new switchers are currently available to order. Additional information on these and Gefen’s entire line of HDTV switching solutions may be found at Gefen.com.
About Gefen:
Gefen leads the industry in just-in-time audio/video solutions for both professionals and consumers with an eye for superior quality and reliable performance. In the HD digital domain, Gefen delivers advanced technologies with multi-platform extension, switching, distribution and conversion capabilities. Gefen equipment is valued all over the world in professional AV/IT and consumer electronics/home theater environments.
Their add-on hardware maximizes system functionality by enabling AV systems to operate beyond their original capabilities. Gefen’s hard working solutions support the popular connectivity interfaces of today, including HDMI, DVI, dual link DVI, HD-SDI, VGA, USB, Firewire and RS-232. A selection of high quality cabling is also available. Visit www.gefen.com for detailed product information.
