Home > Message Board > Press Releases > Archive through 2008 > Archive through September 12, 2006 > Peerless to Show New One Mount™ Flat Panel Modular Mount at CEDIA Expo 2006
Booth number 623, CEDIA Expo 2006
Peerless Industries, Inc., the industry leader in professional-grade audio/visual mounting solutions, will unveil its new One Mount™ Flat Panel Modular Mount for LCD and plasma screens from 23 inches to 84 inches at the annual CEDIA Expo 2006, September 14-17 in Denver at the Peerless Booth number 623.
Peerless’ new One Mount™ Flat Panel Modular Mount is a single mount that can accommodate screens from 23 inches to 84 inches weighing up to 250 pounds and has been UL®-tested. It is comprised of three interlocking wall plates that can be used together or separately, depending on screen size. These plates fit easily into position and can be held together using a minimum of two screws in a two-plate configuration or a maximum of only four screws in a three-plate configuration. Designed to enable quick and easy installation in residential or commercial applications, it comes in a compact package that reduces shelf and storage space for professional installers and retailers.
For more information, visit the Peerless both, number 623, at CEDIA Expo 2006, www.peerlessmounts.com or call 800-865-2112.
