Home > Message Board > Press Releases > Archive through 2008 > Archive through November 27, 2006 > New KwikPeek Wireless Remote Camera Ideal For Home Or Business Use.
www.wirelessimaging.com
(Lino Lakes, Minnesota) - It's a new technological product that offers unprecedented capabilities in the field of wireless remote cameras. The KwikPeek is a wireless battery-powered camera system that has all the breakthrough technologies of current products, as well as some unique benefits for consumers. One of the things that set the KwikPeek apart from other wireless camera systems is that it can operate for several months on just one set of AA batteries. Most similar cameras on the market can only operate for around 10 hours on a single set of AA batteries. Secondly, the KwikPeek will shut off automatically based on the chosen timer settings.
The patented KwikPeek has been created to serve a variety of security and monitoring functions without the hassle of complicated setup, wiring and operation. This system sends wireless video over 300 feet through walls & floors to any TV. The KwikPeek takes less than 10 minutes to set up, can operate up to four cameras on one system, and includes a long-range, RF, handheld remote control unit. The KwikPeek allows for live audio and color video and has four channels per camera to help avoid interference. Because the user can turn the camera on and off remotely, the system can be used for monitoring the front door or driveway, children or infants, residence or small businesses. It can also be used for any legal activity where a wired video connection is undesirable.
The handheld transmitter sends a command signal to turn the KwikPeek on and then captures and sends real time audio/video to the receiver attached to the television. The camera will transmit for up to 5 minutes at a time depending on the adjustable setting. The camera can be turned off with the handheld or will turn off automatically once the pre-set time has elapsed. An auto encryption allows over 16,000,000 addresses for uniqueness and security. There is even an optional hand held monitor for a truly portable monitoring or security solution. An adjustable lens lets the user focus on objects far and near. Another benefit is that it sports a weather resistant housing for use outdoors
"The KwikPeek offers a unique solution to the problems associated with remote wireless viewing and a limited battery life," says Wireless Imaging President Scott Jezierski. "This system solves one of the most common problems associated with transmitting and receiving devices." Jezierski says this technology would be particularly beneficial when integrated with the latest IP Network Cameras.
The KwikPeek can be purchased online for $199 at www.wirelessimaging.com
or by calling 1-800-676-3402
