Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through November 27, 2006 >
Crestron Isys TPS-4L Compact Wall Mount Touchpanel Introduced
| Posted by Admin on Sunday, November 12, 2006 - 05:04 pm: |
Crestron introduces the next generation Isys® TPS wall mount touchpanel at EHX booth #1909. Crestron's latest Isys touchpanel delivers amazing performance in a compact size. In the space of a common light switch, the TPS-4L packs a bright, high-contrast 3.6" active-matrix color touchscreen with vibrant 16-bit Isys color graphics and 10 white backlit pushbuttons.
The TPS-4L delivers the power and flexibility of a custom designed touchpanel interface in a discreet 3.6" flush mount display. The new high-contrast, ultra-bright screen is easily viewable at almost any angle, even in daylight. The 320x240 resolution, 16-bit graphic provide the most vivid icons in a panel of this size. Ten backlit, programmable pushbuttons offer instant access to the most frequently used functions such as channel selection and volume control.
The Isys engine produces astonishing full-color graphics with lightning-fast performance and incredible versatility. A 32-bit Motorola ColdFire® Microprocessor combines with an ultra efficient operating system to support high-resolution graphics and images, dynamic text, full-motion video, animation, multimode objects (buttons, frames, gauges, and sliders) and popup/dropdown sub-pages. Crestron's exclusive Synapse Image Rendering Algorithm enables system programmers to produce amazing graphics - faster and easier. Advanced anti-aliasing delivers crisper, sharper objects and text. Enhanced 3D effects add new depth and style.
Crestron's new TPS Series of touchpanels are fully compatible with standard CAT5 Ethernet connectivity and Crestron's exclusive QuickMedia (QM) transport. QM is Crestron's innovative technology that streamlines presentation system design and simplifies installation by virtually all audio and video signals, and standard 10/100BaseT Ethernet over a single CAT5e or CAT6 type cable.
For more information about the new TPS-4L visit EHX booth #1909 or go to http://www.crestron.com/products/show_products.asp?jump=1&model=TPS-4L
