Home > Message Board > Press Releases > Archive through 2008 > Archive through November 27, 2006 > Dialogic® broadens TDM/IP hybrid offering by adding ISDN BRI connectivity to ...
Dialogic® broadens TDM/IP hybrid offering by adding ISDN BRI connectivity to Host Media Processing
MONTREAL, Quebec. November 21, 2006 — Dialogic Corporation (“Dialogic”) today announced the release of a new version of Diva SIPcontrol software. By using off-the-shelf Diva BRI telephony adapters, Dialogic Host Media Processing (HMP) software, and the new release of Diva SIPcontrol software developers can deploy SIP and HMP based unified messaging, IVR and contact center application into existing BRI network environments.
The combination of Diva SIPcontrol and Diva BRI telephony adapters creates an ISDN BRI to SIP gateway subsystem that can be integrated into a Windows® server running an HMP application. This approach enables the application and the gateway subsystem to communicate via the open and standards-based SIP protocol. Call control information of the Diva telephony board is translated into SIP messages and voice channels are converted into IP packets and streamed via the RTP protocol into the HMP environment.
“We are very excited to introduce an integrated solution set from the Eicon and Intel product families to the market so rapidly after the creation of the new Dialogic.” states Jim Machi, VP of Marketing for Dialogic. “The combination of our market leading HMP software and BRI ISDN telephony interfaces provide a compelling hybrid solution that fits the needs of SIP application developers who need to deploy their systems into both TDM and VoIP networks.”
The ‘glue’ that brings this solution together is the Diva SIPcontrol software, effectively a media gateway that interfaces the telephony adapters to the HMP software. Dialogic looks forward to extending this solution set to other Diva telephony adapters, both digital and analog, in the near future with global availability.
“As a former value added distributor for both Eicon and Intel communication technologies, we are encouraged to see the immediate benefit of the combined product lines that Dialogic has delivered,” states Josef Bressner for Bressner Technology GmbH. “the Diva BRI boards and HMP software are a winning combination for enterprise developers seeking to deploy IP based applications into today’s hybrid network environment.”
The solution also handles T.30 and T.38 fax via the DSP resources of the Diva telephony boards which terminate the TDM fax call and convert V.34 fax modulation into fax over IP for transport. As a result, fax information can be relayed to the HMP application using the industry standard T.38 protocol. The addition of the fax protocol enables unified messaging and multi-mode contact center applications to take advantage of this new solution set from Dialogic.
Diva SIPcontrol v1.2 software for Windows is currently available as a beta release for test and development. General availability is expected in January 2007. Dialogic BRI telephony adapters and Dialogic Host Media Processing software are currently available through value added distributors of Dialogic products.
About Dialogic
Dialogic Corporation is a leading provider of open systems platforms to both the Enterprise and Service Provider markets. The platforms enable converged communications, allowing service providers, developers and system integrators to deliver services, content and applications using multimedia processing and signaling technologies.
Dialogic was formed when Eicon Networks Corporation completed its acquisition of Intel Corporation’s Media and Signaling business and simultaneously announced that Eicon’s name would change to Dialogic Corporation.
Headquartered in Montreal, Dialogic and its subsidiaries have over twenty offices worldwide, providing local presence, knowledge and support to serve its customers around the globe. Dialogic’s Research and Development centers are based in Canada, USA, Germany, UK and Ireland.
Information about Dialogic is available at www.dialogic.com.
Dialogic, Eicon Networks and Eicon, EiconCard, and Diva are either registered trademarks or trademarks of Dialogic Corporation or its subsidiaries. The names of actual companies and products mentioned herein are the trademarks of their respective owners. Dialogic encourages all users of its products to procure all necessary intellectual property licenses required to implement their concepts or applications, which licenses may vary from country to country.
CONTACTS
For Dialogic:
Bill Bryant
Director of Marketing
503-206-4492
Bill.Bryant@Dialogic.com
