Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through January 03, 2007 >
Panasonic LM-RF55LV Dual-Layer 8cm DVD-R Disc Announced
| Posted by Admin on Wednesday, December 13, 2006 - 03:00 am: |
Panasonic, the leading brand of Matsushita Electric Industrial Co., Ltd., announced that the company will release single-sided dual layer 8cm (3-inch) DVD-R discs next spring in the United States. The discs feature 2.6GB capacity, which enables approximately 40 minutes'* of continual recording with the AVCHD High Definition camcorder format. Thanks to specially developed hard coat technology, the surface of the disc is extremely scratch resistant, allowing the disc to be handled easily and safely.
*When recorded with Panasonic HDC-DX1
The following two models will be introduced in the U.S. market:
| Model No | Configuration | Suggested Retail Price |
| LM-RF55LV | single pack | $14.99 |
| LM-RF55LV2 | 2-packs | $29.99 |
40 Minute Continual Recording with High Definition Quality
Single-sided dual layer technology achieves 2.6GB large capacity, an increase from 1.4GB for a conventional single layer disc. It enables the disc to continually record High Definition quality video for approximately 40 minutes without turning over the disc during shooting.
High scratch resistance due to hard coating
A specially developed hard coat technology realized a significant boost in disc resistance to scratches, which ensures easy handling of the disc even in outdoor use as well as extra protection for your important videos.
Lightweight and shock-proof case
Lightweight and soft material is used for the case. It is convenient to carry and even if dropped it does not break easily. The case has a label allowing the user to easily check the recording format, which helps users to recognize the format when playing back the disc.
Specifications
| Product name | 8cm DVD-R disc for DVD camcorder |
| Model No. | LM-RF55LV / LM-RF55LV2 |
| Type | Recordable |
| Disc Diameter/Thickness | 80mm X 1.2mm |
| Base film material | Polycarbonate |
| Recording film material | Organic dye material |
| Capacity | 2.6GB (single sided, dual layer) |
| Recording time | Approx 40 min (AVCHD format NH mode) |
About Panasonic Consumer Electronics Company
Based in Secaucus, N.J., Panasonic Consumer Electronics Company is a division of Panasonic Corporation of North America, the principal North American subsidiary of Matsushita Electric Industrial Co. Ltd. (NYSE: MC) and the hub of Panasonic's U.S. marketing, sales, service and R&D operations. Information about Panasonic and its products is available at www.panasonic.com.
