Home > Message Board > Press Releases > Archive through 2008 > Archive through January 17, 2007 > New 4x4 DVI KVM Matrix Offers Total System Integration for Computers Connecte...
New 4x4 DVI KVM Matrix Offers Total System Integration for Computers Connected to Digital Monitors
WOODLAND HILLS, CA - A newly designed matrix switching system from Gefen performs a valuable role--integrating multiple computers among multiple DVI displays and USB connections.
The new 4x4 DVI KVM Matrix enables four cross-platform computers to be accessed independently from four separate locations, viewed on any four high resolution displays which use DVI connectors.
High-speed USB 2.0 components are switched along with the video for each computer, giving full KVM (keyboard, video, mouse) functionality. Users can also access other USB peripherals with the ability to connect multiple workstations within the same location.
Installation is simple: connections to and from the unit provide four DVI and USB inputs and four DVI and USB outputs as well as a remote control connection.
To operate, users assign any computer to any DVI display. This selection can be performed using the IR remote or the RS-232 serial connection. Switching between sources and displays occurs in milliseconds, with full KVM access guaranteed.
Offering an attractive and simple architecture to network multiple computer systems, the Gefen 4x4 DVI KVM Matrix supports multiple resolutions up to 1920x1200 for computer monitors.
The Gefen 4x4 DVI KVM Matrix (MSRP $999) comes with the RMT-16 IR remote control unit, four DVI and USB cables, rack ears and power supply.
http://www.gefen.com/kvm/product.jsp?prod_id=4314
About Gefen:
Gefen delivers professional quality audio/video solutions with multi-platform extension, integration, distribution and conversion capabilities. Gefen equipment is valued all over the world in professional AV/IT and consumer electronics/home theater environments. Their add-on hardware maximizes system functionality by enabling AV systems to operate beyond their original capabilities. A selection of high quality cabling is also available. Visit www.gefen.com for detailed product information.
