Home > Message Board > Press Releases > Archive through 2008 > Archive through February 06, 2007 > Trends Audio updates TA-10 Class-T Amp, adding a wider soundstage !
ITOK Media Ltd's innovative Hi-Fi brand Trends Audio launched their new palm-top amplifier - Trends TA-10.1 Class-T Amp. It has upgraded the board to version 1.1 with bigger and better input and power capacitors. Meanwhile, Trends TA-10.1 applied much proprietary techniques into their circuit design, components matching, sound tuning and even the case grounding and shielding.
"We are proud to our new Trends TA-10.1. Now it has fuller bass, improved dynamics, better channel separation and a wider soundstage" the chief designer of Trends Audio, Ricky Leung said. New Trends TA-10.1 has upgraded the power filtering capacitor form 220uF ELNA electrolytic to 1500uF SANYO WG (high freq., low ESR) electrolytic and the input coupling capacitor is also upgraded. Trends TA-10.1 applied Tripath's class-T technology and use their unique audio techniques for this palm size amp. It has only 0.4 KG weight with aluminum case and its price is only one fifth to one tenth of the same quality amplifiers.
"As we believe, audiophile amplifier is no longer -- The Larger, the Heavier & the Hotter, the Best Sound," David Ho, the marketing director of Trends Audio said, "Trends TA-10.1 applied the well accept Tripath's class-T audio amplification technology. This integrated the class-D digital audio signal processing technique (PWM) with the Class-AB power amplification into a small IC. It has the mini-size, low heat advantages of Class-D amplifiers and also has the high fidelity sound quality of Class-AB amplifiers".
For circuit & function design improvement of Trends TA-10.1, there are much more thoughtful functions for audiophiles:Trends TA-10 Class-T Amp. has received prize from audiophiles worldwide and they are looking for dealers to resell their products. The suggested retail price of Trends TA-10.1 is US$119 including the AC power adaptor and it may be the most competitively priced amplifiers on the market.
