Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through February 06, 2007 >
DNA introduces Sonic Décor on-wall speakers
| Posted by Donald North on Monday, February 05, 2007 - 02:53 am: |
Compact in size and being on 4.25 inches (10.8 cm) deep, they match perfectly with pictures, paintings, plasma and LCD flat panel TV's.
No need for costly custom installation and cutting big holes in walls like in-wall speakers require, the Sonic Décor on-wall speakers mount with 2 small screws and incorporate an innovative mounting bracket with built-in channel for bubble level. From unpacking to perfectly level wall mounting and wiring, the Sonic Décor speakers can be playing your favorite tunes in less than 30 minutes.
From classic to contemporary, customers can choose among many colors for the cabinets, grilles, and trim panels. Over 80 color combinations are standard. Any color combination is offered at the same price. Blank trim panels are also available for custom painting by customer or installer.
The model 100 left/right mirror-imaged pair speakers measure 16.25 inch high x 10.5 inch wide x 4.25 inch deep and weigh 13 pounds each. The model 100's feature a 5.75 inch woofer with 1 inch textile dome tweeter. Frequency range is 70 Hz – 20 kHz. US retail price is $1495 per pair including 1pr grilles and 1pr trim panels.
The mating model 200 center channel speaker measures 10.5 inch high x 16.25 inch wide x 4.25 inch deep and weighs 13 pounds. It features also features a 5.75 inch woofer with 1 inch textile dome tweeter in vertical alignment with wide, uniform horizontal dispersion for natural, clear speech and vocals. Frequency range is 70 Hz – 20 kHz. US retail price is $795 each including 1pc grille and 1pc trim panel.
The DNA Sonic Décor speakers are made in the USA.
High-resolution photos available. Kindly e-mail a request.
Donald North Audio
Los Angeles, California
www.dnaudio.com
Tel: 310 869 6214
