Home > Message Board > Press Releases > Archive through 2008 > Archive through February 22, 2007 > Legacy 4GB Fully Buffered DIMM Announced
Electronics Eliminates Need for Dual Die Devices, Offers Cost Savings
PC design engineers and system integrators now have a new, immediately available option for a fully buffered dual in-line memory module (FB-DIMM) that offers high density in a standard form factor. The 4GB DDR2 FB-DIMM from Legacy Electronics is a JEDEC-standard, pin-out DIMM offering a low-profile (1.18 inch or 30mm) PCB height in speeds ranging from PC2-3200 to PC2-5300. This means that Apple- and Intel-platform designers, and more specifically any high-speed, high-density blade server and 1U-Chassis designers, can address their applications' needs without stacking or use of dual die devices. This new DIMM option translates to a significant cost savings and increased performance in most designs.
Jason Engle, president of Legacy Electronics, added, "We believe Legacy is first to market with a qualified 4GB FB-DIMM for both the Apple and Intel platforms. Our design meets the height restrictions necessary for a 1U server chassis, and the popular MacPro."
Legacy's new 4GB FB-DIMM also provides the reliability of Advanced Memory Buffer (AMB), which replaces registers and phase lock loops (PLLs) used on other DIMMs. The AMB buffers the DRAM devices from the channel, and uses a high-speed, point-to-point differential interface to communicate with the controller. This process translates to increased system memory capacity, reduced memory channel pin count, and higher reliability.
Availability and More Information
The 4GB DDR2 FB-DIMM is available now in 100-unit quantities at $895. More information is available by contacting Legacy Electronics. For details on worldwide sales representatives and distributor locations, go to http://www.legacyelectronics.com/corporate_contactus.php, call 949-498-9600, or toll-free at 888-466-3853.
About Legacy Electronics
Founded in 1993 and located among the new high-technology companies of South Orange County, California, Legacy Electronics is home of the patented Canopy® chip-stacking alternative, a three-dimensional printed circuit board subassembly and process technology. Legacy also manufactures the low-form-factor Point Seven™ memory module product line.
Legacy Electronics is an ISO 9001:2000 certified manufacturer, designer and tester of high-speed, high-density memory modules, printed circuit boards, and other computer products. All Legacy Electronics memory modules are RoHS* and EWRA** compliant.
*Restriction of Hazardous Substances Directive, adopted in February 2003 by the European Union, took effect July 1, 2006, restricts use of (6) hazardous materials in the manufacture of various types of electronic and electrical equipment.
**Electronic Waste Recycling Act (CA, SB20), effective July 1, 2007.
