Home > Message Board > Press Releases > Archive through 2008 > Archive through April 05, 2007 > Roku SoundBridge 2.7 Software Released
Upload Upload
Roku is excited to announce the availability of a new version of software for your SoundBridge. This 2.7 firmware update is free, has some great new additions, and is easy to get.
A simple way to update your SoundBridge is to unplug it, wait 5 seconds, and then plug it back in. After it "boots up" it will automatically check for and offer you a software update. If this does not work for you, use the Software Update menu which you'll find in "Change Server and System Configuration". Here's what's new in 2.7:
Major new features in 2.7: Other improvements in 2.7:Updating Your SoundBridge or SoundBridge Radio's Software
To update SoundBridge software, follow these instructions using your SoundBridge remote control:
  1. Make sure your SoundBridge or SoundBridge Radio is connected to a network with Internet access and powered on.
  2. Press the Menu button on the remote control.
  3. Navigate down to "Change Library or Configuration" and press Select.
  4. Navigate down to "System Configuration" and press Select.
  5. Select "Software Version and Updates".
  6. You will be shown your current software version and be given the option to check for a software upgrade.
  7. Choose "Yes" to check for software upgrades for your SoundBridge or SoundBridge Radio.
  8. You should see a screen with the progress bar and the message: "Contacting Server..."
  9. You will then see one of the following two screens:
    • "Your Software is Up to Date". Select 'OK' to return to the System Configuration menu.
    • "New Software 2.7 is available. Perform Upgrade?". Choose "yes" to download and install the upgrade. Once the upgrade completes, you will be prompted to reboot the unit. Once it reboots, it will be running the new software.
