Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through April 05, 2007 >
Niles StageFront Home Theater Solutions Now Shipping
| Posted by Marketing Ma... on Wednesday, March 21, 2007 - 12:04 pm: |
MIAMI, FLORIDA – March 19, 2007 – Niles Audio Corporation, The First Name in Custom Installation®, announced today the shipment of StageFront Home Theater Solutions™, a new line of loudspeakers designed specifically for home theater applications, to Niles factory-authorized dealers worldwide. In creating StageFront Home Theater Solutions, Niles is invigorating home theater with the same passion and application-specific design that propelled the company to the top of the custom installation marketplace.
StageFront has distinct benefits over traditional home theater loudspeakers, including features that help custom installers. The entire StageFront series includes both in-wall and cabinet models that are voice-matched to deliver consistent uniform sound quality, regardless of loudspeaker type. This frees custom installers to design systems incorporating some models that are built into cabinets or placed on stands, with others that are built into walls, optimizing performance, appearance and design flexibility. This is a feature unique to Niles, as no other brand on the market today offers voice-matched dedicated and in-wall home theater loudspeakers that can be mixed and matched.
Other CI specific features include 12-Volt trigger activated bi-pole/di-pole switching, pivoting midrange/tweeter pods and resonance-controlling cabinets for predictably-precise imaging. Advanced technology drivers with cast baskets, carbon-fiber woofers and fluid-cooled Teteron tweeters ensure a dynamic impact that’s on par with the best movie theaters. Named best of show at CEDIA EXPO 2006 by the Absolute Sound and the recipient of a CES 2007 Innovations accolade, StageFront Home Theater Solutions is poised to become the world’s premier home theater loudspeaker line.
“StageFront Home Theater Solutions has been a true labor of love for Niles,” said Frank Sterns, president of Niles Audio Corporation. “The line was created by custom installers for custom installers, with their home theater needs and design challenges in mind. The response we have received from our dealers has been overwhelmingly positive,” Sterns added.
StageFront Home Theater Product Family Details:
In-Wall Series
StageFront In-Wall Loudspeakers include four LCR models and two dedicated Surround Effects loudspeakers. All feature a ported enclosure tuned specifically for maximum sensitivity, dynamics and high-fidelity sound in an in-wall application. All fit within a standard 2x4 stud-wall depth. A steel bezel permanently affixed to the baffle board enables drivers to be placed as far forward as possible and provides for maximum use of the air volume within the wall. Each loudspeaker is equipped with epoxy-coated flat-steel grilles using a magnetic attachment method and a captured toggle bolt mounting system with metal dogs for easy retrofit installation.
• IW2550 LCR: An enclosed in-wall loudspeaker featuring 5” TCC woofers and a 1” Teteron tweeter in a D’Appolito array for controlled dispersion in a home theater application. Can be used as a left, center or right channel loudspeaker. Suitable for vertical or horizontal mounting. MSRP: $499.95 each
• IW2650 LCR: An enclosed in-wall loudspeaker featuring dual 6” TCC woofers and a 1” Teteron tweeter in a D’Appolito array for controlled dispersion in a home theater application. Can be used as a left, center or right channel loudspeaker. Suitable for vertical or horizontal mounting. MSRP: $599.95 each
• IW650 FX: An enclosed in-wall special effects loudspeaker featuring a forward-firing 6” TCC woofer, 1” Teteron tweeter and dual 87 mm full-range TCC special effects drivers placed at opposing angles. Includes Dipole/Bipole switching via a front-mounted switch or 12V rear-mounted trigger input and an “effects” level control that adjusts the relative level of direct-radiating drivers to the special effects drivers. MSRP: $1399.90 per pair
• IW2670 LCR: An enclosed in-wall loudspeaker featuring dual 6” carbon-fiber woofers and an adjustable, pivoting midrange/tweeter pod with a 1” Teteron tweeter and 1 1/2” Teteron dome midrange. The pod can be rotated for horizontal or vertical mounting and includes tweeter, midrange and pod level controls. Can be used as a left, center or right channel loudspeaker. MSRP: $899.95 each
• IW2770 LCR: An enclosed in-wall loudspeaker featuring dual 7” carbon-fiber woofers and an adjustable, pivoting midrange/tweeter pod with a 1” Teteron tweeter and 1 1/2” Teteron dome midrange. The pod can be rotated for horizontal or vertical mounting and includes tweeter, midrange and pod level controls. Can be used as a left, center or right channel loudspeaker. MSRP: $1199.95 each
• IW770 FX: An enclosed in-wall special effects loudspeaker featuring a direct 7” carbon-fiber woofer and 1” Teteron tweeter. Special effects drivers are on an angled baffle board with dual 4” carbon fiber woofers and dual 1” Teteron tweeters. Includes Dipole/Bipole switching via a front-mounted switch or 12V rear mounted trigger input and an “effects” level control that adjusts the relative level of direct radiating drivers to the special effects drivers. MSRP: $2,399.95 per pair
Pro Series
StageFront Pro loudspeakers include four LCR models, two dedicated on-wall Surround Effects models and a high-performance box subwoofer. All feature sealed box construction for accurate extended low frequency response. Enclosures are constructed from 1” medium density fiberboard and are finished in gloss black with sculpted metal grilles. Box dimensions are specifically designed to match rack-mount cabinet width when the loudspeakers are placed vertically or horizontally.
• Pro1770 LCR: A sealed box loudspeaker with a 7” carbon fiber woofer with rubber surround and an adjustable, pivoting midrange/tweeter pod with a 1” Teteron tweeter and 1 1/2” Teteron dome midrange. The pod can be rotated for horizontal or vertical mounting and includes tweeter, midrange and pod level controls. Can be used as a left, center or right channel loudspeaker. MSRP: $599.95 each
• Pro2770 LCR: A sealed box loudspeaker with dual 7” carbon fiber woofers with rubber surround and an adjustable, pivoting midrange/tweeter pod with a 1”Teteron tweeter and 1 1/2” Teteron dome midrange. The pod can be rotated for horizontal or vertical mounting and includes tweeter, midrange and pod level controls. Can be used as a left, center or right channel loudspeaker. MSRP: $799.95 each
• Pro770FX: An on-wall special effects loudspeaker featuring a 7” carbon fiber woofer and an adjustable, pivoting midrange/tweeter pod with a 1” Teteron tweeter and 1 1/2” Teteron dome midrange. The pod includes tweeter, midrange and pod level controls. Special effects drivers include dual 4” carbon midrange drivers and dual 1” Teteron tweeters. Includes Dipole/Bipole switching via a front mounted switch or 12V rear mounted trigger input and an “effects” level control that adjusts the relative level of direct radiating drivers to the special effects drivers. MSRP: $1599.95 per pair
• Pro1870 LCR: A sealed box loudspeaker with an 8” carbon fiber woofer mated to a cast aluminum midrange/tweeter pod with special high frequency horn for added dynamics. Midrange/tweeter pod contains a 4” carbon fiber woofer and 1” Teteron tweeter. The pod can be pivoted for off-axis listening positions or rotated 90 degrees to accommodate horizontal or vertical placement. Pod includes controls for midrange and tweeter levels, as well as boundary compensation. The Pro1870 LCR can be used as a left, center or right channel loudspeaker. MSRP: $1099.95 each
• Pro2870 LCR: A sealed box loudspeaker with an 8” carbon fiber woofer mated to a cast aluminum midrange/tweeter pod with special high frequency horn for added dynamics. Midrange/tweeter pod contains a 4” carbon fiber woofer and 1” Teteron tweeter. The pod can be pivoted for off-axis listening positions or rotated 90 degrees to accommodate horizontal or vertical placement. Pod includes controls for midrange and tweeter levels and boundary compensation. The Pro2870 LCR can be used as a left, center or right channel loudspeaker. MSRP: $1499.95 each
• Pro870 FX: An on-wall special effects loudspeaker featuring a forward-firing, 8” cast-frame, carbon-fiber woofer with rubber surround mated to a cast aluminum midrange/tweeter pod with special high frequency horn for added dynamics. Midrange/tweeter pod contains a 4” carbon fiber woofer and 1” Teteron tweeter. The pod can be pivoted for off-axis listening positions and includes controls for midrange and tweeter level. Special effects drivers include dual 4” carbon fiber midrange drivers and dual 1” Teteron tweeters mounted at opposing angles. Includes Dipole/Bipole switching on a front mounted switch or 12V rear mounted trigger input and an “effects” level control that adjusts the relative level of direct radiating drivers to the special effects drivers. MSRP: $2599.95 per pair
• Pro15: A high-performance, vented box subwoofer featuring a 15” cast frame, carbon fiber woofer and an advanced, 1000W digital amplifier. Includes front-mounted low-pass, phase and level controls, music/movie mode controls and LFE input. MSRP: $1799.95 each
Talking Points
• Niles is shipping StageFront Home Theater Solutions, a new line of loudspeakers designed specifically for home theater applications, to factory-authorized dealers worldwide.
• In creating StageFront Home Theater Solutions, Niles is invigorating home theater with the same passion and application-specific design that propelled the company to the top of the custom installation marketplace.
• Engineered to deliver robust, cinema-like sound, the StageFront line consists of six in-wall loudspeakers and seven “Pro” series box loudspeakers – which include four box loudspeakers, two on-wall “special effects” loudspeakers and one high-performance subwoofer.
• StageFront has distinct benefits over traditional home theater loudspeakers with features unique to custom installation.
• Named best of show at CEDIA EXPO 2006 by the Absolute Sound – and the recipient of a CES 2007 Innovations accolade, StageFront is poised to become the world’s premier home theater loudspeaker line.
Corporate Information
Niles Audio Corporation, based in Miami, is a 29-year-old company recognized as the First Name in Custom Installation®. As a leading designer, manufacturer and marketer of audio/video custom installation products, Niles Audio is guided by seven principles: a commitment to reliable, high-performance, application-specific, product design, a complete and up-to-date product assortment with just-in-time delivery, extensive training and technical support, exemplary customer service and strong dealer relationships. Niles is a brand based on strength, reliability and outstanding performance with a wide range of award-winning, innovative products.
Additional information may be obtained by contacting Mike Detmer at Niles Audio Corporation, 12331 SW 130th Street, Miami, FL 33186 (1-800-BUY-HIFI; ext. 197) or by visiting: www.nilesaudio.com.
Niles, The First Name In Custom Installation, and Blending High Fidelity And Architecture are registered trademarks of Niles Audio Corporation in the United States and/or other countries. All other trademarks are property of their respective owners.
