Home > Message Board > Press Releases > Archive through 2008 > Archive through April 05, 2007 > Automate repetitive and tedious tasks on computers
GoldSolution Software announces the release of Easy Macro Recorder 3.61, a handy utility for the Windows operating system that records what you operate and creates a replayable script.
Nowadays, more and more people use computers to do some tasks, and there are lots of duplicate works such as typing the same letters, copy & paste lots of data and send emails. It makes people tedious and boredom. It will be great if there is a tool which automatically does the duplicate things for you.
Easy Macro Recorder automates repetitive and tedious tasks on computers. It records all operation of mouse and keystrokes, and saves them as macros, then Easy Macro Recorder can play back the recorded macros to automate tasks any number of times. There is an easy-to-use macro editor which can help you create new macros or edit an already created macros. Easy Macro Recorder works on any Windows applications.
Easy Macro Recorder is very easy to use, just three steps: record, save and play back. It doesn't require any programming experience.
Easy Macro Recorder is the right choice for tasks automation. It is both affordable to every computer user and a real value.
System Requirements
Easy Macro Recorder will run under Windows 98, Me, NT, 2000, XP and 2003 on an Intel-based 586 PC or greater. The program requires 32 MB of RAM and 2 MB disk space to install.
Price and Availability
Easy Macro Recorder is available now. The price for single user license is $29.95 USD. A trial version is available from the flashplayerpro.com web site at:
http://www.flashplayerpro.com/MacroRecorder/
EVALUATION COPIES ARE AVAILABLE ON REQUEST
