Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through April 05, 2007 >
Scand Unveils dhtmlxCombo Ajax Combobox with Autocomplete
| Posted by Ivan Petrenko on Friday, March 23, 2007 - 02:21 pm: |
Minsk, Belarus, March 23, 2006 Scand LLC announced the release of new Ajax-based UI component dhtmlxCombo v1.0. Its a JavaScript combobox control which provides suggestion search and automatic completion functionality to web-based applications. Being cross-browser compatible, easy to integrate and completely configurable, dhtmlxCombo helps developers effortlessly create dynamic auto-completing dropdown lists.
dhtmlxCombo can be easily converted from existing HTML SELECT or populated with JavaScript. Thanks to Ajax support the component works fast and smoothly with large sets of data, loading list of suggestions dynamically on demand. Working example which handles 100,000 records is available on combobox homepage.
The component features type-ahead, keyboard support and ability to display images in the dropdown list. Working as autocomplete tool, dhtmlxCombo requests content from server as user types in the input field and provides a list of relevant values.
dhtmlxCombo can be used in four modes:
editable select box user can either select a value from the list or type a custom value;
read-only select box user can select just one value from the list;
filter all the data is loaded on the client-side and as user begins to type, the list is narrowed to the appropriate values basing on the first typed symbols;
autocomplete the list is loaded and shown as user types in input box, autocomplete text appears basing on first typed symbols.
Live examples for each mode and detailed information about dhtmlxCombo can be found here: http://scbr.com/docs/products/dhtmlxCombo/
About Scand LLC
Scand LLC is the software development company based in Belarus (Eastern Europe). The company provides offshore outsourcing software development services in areas of J2EE, .NET, C++, PHP programming for companies worldwide. Scand LLC offers a set of advanced ready to use Java applets and JavaScript components that are available for download on Scand Website.
